DaveHT70 Offline
#1 Posted : Wednesday, 14 March 2012 9:44:44 AM(UTC)
DaveHT70
G'day,
I just wanted to share some info that I found out today, I have spoken to a few locals recently who have changed over standard alloy steel bolts to stainless steel bolts while restoring their cars, now I can understand why people would consider doing this as it has less corrosion and also looks good. BUT, it does not have the same strength as alloy steel bolts, so one has to be careful where you use them. Alloy steel bolts are quenched and tempered making them harder where stainless steel bolts have not been. Below is a table of the differences:
Class & Material.....Min. Yield Strength (Mpa).....Min Tensile Strength (Mpa)
Class 8.8.......................640-660.................................800-830 med. carbon steel
Class 10.9.....................940......................................1040 alloy steel
Class 12.9....................1100.....................................1220 alloy steel
A-2 Stainless..................210 min.................................500 min.
....................................450 typical.............................700 typical
Yield Strength: The maximum load at which a material exhibits a specific permanent deformation.
Tensile Strength: The maximum load in tension (pulling apart) which a material can withstand before breaking or fracturing.
Edited by user Wednesday, 14 March 2012 9:54:17 AM(UTC)  | Reason: Not specified
"Reality is an illusion. Albeit a very persistent one"
peter_flane Offline
#2 Posted : Wednesday, 14 March 2012 9:51:45 AM(UTC)
peter_flane
Definitely only use stainless bolts on body panels and ornaments. Never on mechanical parts.
ozchevy Offline
#3 Posted : Wednesday, 14 March 2012 4:16:12 PM(UTC)
ozchevy
Off the shelf, a Stainless steel Bolt isnt as strong as a Grade 8.8, but don't write off the Stainless bolt yet.
I say this with caution, because you have to know what your doing, but a Stainless bolt can be made tougher than a Grade 8.8 with the know how. It's all about the heating and cooling process to harden it.
I won't go into detail on here - but I will say the bolt is cooled very slowly in common Lime as found in the Gardening section of your local plant nursery or Hardware store. You will also require a Rockwell Hardness Test rig/machine - which costs a couple of grand.
Edited by user Wednesday, 14 March 2012 4:16:52 PM(UTC)  | Reason: Not specified
DaveHT70 Offline
#4 Posted : Wednesday, 14 March 2012 6:34:56 PM(UTC)
DaveHT70
One of the guys I know who has a HG recently changed his shocks and decided to replace the alloy steel bolts with stainless steel, during the change over one of the stainless steel bolts snapped while trying to put it into place. This should have been seen as a sign, definitely not a good place to use stainless steel bolts...
#5 Posted : Friday, 16 March 2012 8:10:30 AM(UTC)
Stainless steel is an steel alloy as well, just a different alloy of ferrous metals.
Knowing the tensile strength of bolts and where to use them is the important part.
DaveHT70 Offline
#6 Posted : Friday, 16 March 2012 8:24:28 AM(UTC)
DaveHT70
True, Stainless Steel is a steel alloy with 17-19% Chromium and 8-13% Nickel. The difference is that is hasn't been quenched and tempered which is what gives you the strength.
#7 Posted : Friday, 16 March 2012 11:00:53 AM(UTC)
also consider there is stainless steel and stainless steel.
i have come across so called stainless steel which was highly magnetic and also had some rust properties.
DaveHT70 Offline
#8 Posted : Friday, 16 March 2012 6:12:43 PM(UTC)
DaveHT70
"All stainless steels, with the exception of the austenitic group, are strongly attracted to a magnet.
All austenitic grades have very low magnetic permeabilities and hence show almost no response to a magnet when in the annealed condition; the situation is, however, far less clear when these steels have been cold worked by wire drawing, rolling or even centreless grinding, shot blasting or heavy polishing. After substantial cold working Grade 304 may exhibit quite strong response to a magnet, whereas Grades 310 and 316 will in most instances still be almost totally non-responsive."
This information was sourced from the following web-site:
http://www.azom.com/article.aspx?ArticleID=1140
KeithA Offline
#9 Posted : Saturday, 17 March 2012 4:24:51 AM(UTC)
KeithA
316 stainless is used in marine enviroments and is not attracted by magnets and will not rust. 316 nuts, bolts etc are expensive. 304 is considered stainless, is attracted by magnets and will rust although it takes a long time. 304 can still be polished up to look good. Bolts etc are far cheaper.
ozchevy Offline
#10 Posted : Saturday, 17 March 2012 6:48:30 PM(UTC)
ozchevy
Stainless steel bolts and Hex Allen head Capscrews etc, have a thread form that are Cold Roll Formed, and not cut with Dies.
This gives ductile strength to the bolt because it is forged cold.
If heated by an Induction Element (Not Flame heated) so that a uniform heat of the bolt is applied, the properties of bolt remain little un-changed, and if allowed to cool "very very" slowly (Not quenched) the bolt is toughened immensely. How much is only determined by the use of a Rockwell Hardness test rig.
Stainless steel bolts can be made just as tough as Grade 8.8 bolts and with Tensile strength exceeding 1000 Mpa. You just need to know how to do it, and have the gear on hand.
928S Offline
#11 Posted : Tuesday, 20 March 2012 8:54:06 AM(UTC)
928S
There is some good answers here and wise words, most stainless bolts would really only be good for holding the guards and bonnet on. However as stated there are better stainless bolts around, in fact they can be close to the best. I have some of these in my con rods, the composition is made up roughly as follows,
Nickel 35%, Cobalt 35%, Chrome 20% and Moly 10%
This gives a heat treated Mpa of approx 2,200. It is extremely good in hostile chemical environments, It also resists stress corrosion.
One material that beats the MP35N in terms of tensile strength is C-350, a Maraging steel with a Mpa strength of 2400. It is about 65% iron with the rest being made up of Ni,Co,Mo,Ti, Al but it has no carbon. I use this material in the piston pins. All materials are super clean to achieve these strengths.
Edited by user Tuesday, 20 March 2012 8:55:38 AM(UTC)  | Reason: Not specified
