sexc351 Offline
#1 Posted : Thursday, 19 April 2012 4:38:06 AM(UTC)
sexc351
how do you tell if you have a hk gts bonnet?i know the kingswoods have the holes cut out on the passenger side what about gts?i have a couple of bonnets with no holes for badges,what are these bonnets off?the reason i ask is i am doing up a hk gts and would like an original bonnet
thanks luke
The HKTG Garage Offline
#2 Posted : Thursday, 19 April 2012 6:21:42 AM(UTC)
The HKTG Garage
Luke, you can use any bonnet off a HK to use on your GTS. They are all the same. Obviously Belmont had no studs or holes for the stainless mould. GTS would have three badge holes on the outer skin, drivers side.
The bonnet you refer to with the three large oblong holes at the front underneath on the passenger side are for all HG (except GTS obviously).
HT had the holes for the 'HOLDEN' letters in the centre.
blameyone Offline
#3 Posted : Thursday, 19 April 2012 10:32:52 AM(UTC)
blameyone
So how is the HT & HG standard bonnet different to the std HK ?.....Jack
#4 Posted : Thursday, 19 April 2012 4:50:25 PM(UTC)
As HKTG has said they are different on the underside. They have extra holes in the frame to allow access for the different badges on different models.
Factory HT bonnets have 6 small oval-shaped holes (3 equally spaced either side of centre) behind where the H-O-L-D-E-N letters are mounted on the forward edge.
Factory HG bonnets have a large oval hole behind where the Kingswood, Premier or Monaro script badge is mounted on the passenger side forward edge.
A factory HK bonnet will have neither of these holes.
#5 Posted : Thursday, 19 April 2012 5:47:49 PM(UTC)
Terry, HG normally have 3 x large oval holes under the badge location, but Luke and Jack will get the drift when they see one.
dirty davo Offline
#6 Posted : Thursday, 19 April 2012 7:38:42 PM(UTC)
dirty davo
just to add to that HT prem & brougham never had holden lettering or holes on outside skin, although th 12 round holes are in th inner.
all HG bonnets also had 11 extra holes on inner to accommodate th clips for fitting of under bonnet insulation (as HT & HK were only glued on)
regards DD
sexc351 Offline
#7 Posted : Friday, 20 April 2012 4:35:36 AM(UTC)
sexc351
ok guys so why arent there any holes for the gts badge on the drivers side?there is holes in the boot lid for them.
thanks again luke
sexc351 Offline
#8 Posted : Friday, 20 April 2012 4:39:48 AM(UTC)
sexc351
or is the holes only on the top not underneath?
#9 Posted : Friday, 20 April 2012 4:42:11 AM(UTC)
Only in the skin in HK.
#10 Posted : Friday, 20 April 2012 6:08:35 AM(UTC)
The HKTG Garage
thanks again luke
Only in the skin. The badge used the push in retainers. On HG the badges had speed nuts. Therefore as I said before, you can use any HK bonnet for a HK GTS, just add holes.
