Premier 350 Offline
#1 Posted : Wednesday, 9 May 2012 5:08:53 AM(UTC)
Premier 350
I've got a NASCO vanity mirror that mounts inside the glovebox.
It's a hinged set up that so the mirror can fold away.
My question is: Was the mirror mounted to the top of the glovebox liner or the bottom. Or was it mounted on the glovebox lid?
Can anyone help?
Rhys Offline
#2 Posted : Wednesday, 9 May 2012 7:13:56 AM(UTC)
Rhys
Definitely the top of the glovebox liner, I can get you the exact measurements of where it is mounted if you want.
The ones fitted to HQs all had a piece of foam in the circular recess which I think they deleted in later models.
Before you fit it, nip up the hinge with a small screwdriver so that the mirror stays folded away and doesn't drop down on its own.
Rhys
Premier 350 Offline
#3 Posted : Wednesday, 9 May 2012 7:10:34 PM(UTC)
Premier 350
Cheers, Rhys,
It's not going into a HQ, so I won't need exact measurements, but
thanks for the your offer. And the quick reply.
Thanks again.
#4 Posted : Friday, 11 May 2012 4:26:16 PM(UTC)
Those mirrors where also the same used for valiants and possibly ford in that period.
rimzimmer Offline
#5 Posted : Wednesday, 25 July 2012 5:48:20 AM(UTC)
rimzimmer
Rhys, would it be possible for those measurements and/or a pic of one installed. I just pick up a mirror today and what to get it right.
Rhys Offline
#6 Posted : Saturday, 29 June 2013 8:09:42 PM(UTC)
Rhys
Nearly a year late Rimzimmer but I took some photos while I had the glovebox lid off if you still need them. The distance of the mirror's RH screw hole to the insert's upper central screw hole is 18mm, see photos below. I don't know if all HQ inserts had the mirror holes pre-punched but if not these photos will help.
Edited by user Saturday, 29 June 2013 8:12:10 PM(UTC)  | Reason: Not specified
