Tom118 Offline
#1 Posted : Sunday, 27 May 2012 8:19:59 AM(UTC)
Tom118
Will the stock red motor manifold work or will I need a specific manifold to adapt it?
Also I plan on buying a new air filter, will I have to buy an air filter made for an XE Falcon?
Thank you.
No worries, mate.
BIGCAV Offline
#2 Posted : Sunday, 27 May 2012 8:36:55 AM(UTC)
BIGCAV
there are specific aftermarket airfilters for the webers, like 9" x 2" chrome versions are available
#3 Posted : Sunday, 27 May 2012 9:53:00 AM(UTC)
As you will have to use a adapter plate I would recommend you use either a std holden two barrel manifold or aftermarket two barrel manifold.
This will give you a better flow than adapting from two barrels back to single barrel.
You may find some useful information on doing the conversion here
http://holdenpaedia.oldh...en.com/Weber_Conversion
Cheers Paul.
#4 Posted : Monday, 28 May 2012 4:53:35 AM(UTC)
the best manifolds to use are the holley pattern manifolds, so cain, speco, redline ect will be best
i have manifolds and adaptor plates if you need any
This page was generated in 0.022 seconds.
