Fastlane
Holden Forums
Holden Technical Talk
HK Engine Bay Export Battery Tray Indent
We sorted that one Terry, ALL HQ GTS/4 from Brisbane plant did not have wiring for rear doors to activate the interior lighting system.
One of those strange assembly plant annomilies.
Warren
Warren
So you're saying that ALL GTS 4-doors from ALL other plants did have it. Dr Terry |
Yes, that is right Terry.
Warren
My 2 HQ GTS4's both Melbourne built sept & oct 73, have no rear door lighting looms or holes pressed into the b pillars, my mates sept 74 Sydney built HQ GTS4 had the holes pressed into the b pillars but no loom. |
HOLDEN The Great Way to Move |
I shall go back and check what I have info on again.
Warren
Just some info, my hk327 built sep 68 does not have the boot light wire. I looked at the loom and it doesn't look modified. It's a Sydney built car
Fastlane
Holden Forums
