s_rogers Offline
#1 Posted : Monday, 18 June 2012 3:54:47 AM(UTC)
s_rogers
gday guys i just bought a 308 and supra 5 speed combo out of a hg kingswood to go into my hg belmont... but i am having some trouble finding what the engine originally came out of? got the engine and print date but doesnt registered on any engine number websites
passenger side front of head - 11wb3686 passenger side above water pump facing up - 19K8
if any one could help me to find what my engine originally came from that would help me out so much!
thanks sam
JBM Offline
#2 Posted : Monday, 18 June 2012 5:20:46 PM(UTC)
JBM
It's a very early WB statesman block. Maybe the last number should be zero not eight.
James
#3 Posted : Monday, 18 June 2012 8:07:55 PM(UTC)
WB Deville, but I don't think it is a valid WB engine number. Look harder at it again. WB should be at least 6 digits (after the 11WB).
#4 Posted : Monday, 18 June 2012 11:32:19 PM(UTC)
Shouldn't a WB Statesman engine prefix be 11WTxxxxxx ?
A 1978 casting number is also a bit odd for a WB block.
JBM Offline
#5 Posted : Tuesday, 19 June 2012 3:35:06 AM(UTC)
JBM
Hq blocks started with 1001 so I don't see why the WB blocks didnt do the same.
James
#6 Posted : Tuesday, 19 June 2012 5:56:39 AM(UTC)
Correct, I just assumed he read that wrong!
#7 Posted : Tuesday, 19 June 2012 5:58:04 AM(UTC)
James
They didn't. Number sequence started at either VB Commodore release or with HZ engine numbers. Evidence points to most likely Commodore.
