81837 Offline
#1 Posted : Thursday, 5 July 2012 1:00:37 AM(UTC)
81837
I recently did a temporary diff centre swap on a 308/Glide HT, the 2.78 open centre that came out had a heavier casting requiring two longer mounting bolts (rather than the normal studs) towards the bottom and had a wider yoke than the 3.36 that went in.
Is this a V8 Banjo, or are the higher speed Banjos all beefed up for the extra torque?
Utility8 Offline
#2 Posted : Thursday, 5 July 2012 1:30:43 AM(UTC)
Utility8
Both 2.78:1 & 3.08:1 banjo diffs had the 2 long bolts. My understanding is the casting was larger to accommodate the larger crown wheel, necessitating the 2 long bolt at the bottom rather than the 1 used with all other ratios.
The wider yoke indicates a V8 application.
Edited by user Thursday, 5 July 2012 1:32:25 AM(UTC)  | Reason: Not specified
utility8
#3 Posted : Thursday, 5 July 2012 2:05:09 AM(UTC)
As above, but a wider yoke does not necessarily mean it is a V8 diff, but in this case it will as it was a 2.78:1. All HK with 3.08 banjo got the larger rear uni regardless of engine size.
castellan Offline
#4 Posted : Thursday, 5 July 2012 2:50:20 AM(UTC)
castellan
Does not have a larger crown wheel.
Pinion may be in a different position due to ratio's used.
Utility8 Offline
#5 Posted : Friday, 6 July 2012 7:21:48 PM(UTC)
Utility8
Yep, right you are, pinion not crown wheel.
utility8
