xbgtcoupe Offline
#1 Posted : Thursday, 19 July 2012 8:19:58 AM(UTC)
xbgtcoupe
Hi guys
helping a mate fit a th350 into a hx and have read that speedo cable hole in firewall has to be drilled.
Does anyone have a pic or explain exactly where it needs to be?
#2 Posted : Thursday, 19 July 2012 5:31:25 PM(UTC)
Best to go looking at a factory TH400 car yp see where the hole is, and then you'll find a little guide dimple in that spot to show you where to place the holesaw. From memory it is a 32mm hole, and you'll have to do it before the engine goes in. The cable also gets supported by a clip that screws through the floor on the passenger side. I can probably get you a scan of a parts catalogue showing you the support, but you'll need to view a car to find the spot for the firewall hole.
xbgtcoupe Offline
#3 Posted : Friday, 20 July 2012 6:49:57 AM(UTC)
xbgtcoupe
I have since found out from a business that does heaps of these conversions that the original hole is the way to go.
#4 Posted : Friday, 20 July 2012 6:40:51 PM(UTC)
I've tried that and the speedo tends to shake due to the tight angles on the cable.
Premier 350 Offline
#5 Posted : Monday, 23 July 2012 11:39:11 PM(UTC)
Premier 350
I had a TH400 in my HQ, used the original (202 Trimatic) hole and never had any problems.
Luck of the draw I guess.
