YetAnotherForum.NET Help
Premier 350 Offline
#1 Posted : Wednesday, 5 September 2012 2:25:24 AM(UTC)
Premier 350
Not a burning question, but what did Holden do for shift linkages on the export LHD column shift manual cars?
Run linkages under the gearbox ( like a TH400 column shift)?
justgm Offline
#2 Posted : Wednesday, 5 September 2012 3:57:20 AM(UTC)
justgm
I think they used saginaw ( usa ) 3 speed boxes , as they had linkages on the correct side . Mark.
Premier 350 Offline
#3 Posted : Thursday, 6 September 2012 5:20:29 AM(UTC)
Premier 350
Thanks just GM. That would make sense, I didn't think they turned the Aussie 3 speed upside down!
Cheers.
#4 Posted : Friday, 7 September 2012 2:25:23 AM(UTC)
I have seen drawings for LHD Toranas with 3spd Saginaw but I haven't seen one for a Holden, although it does make sense they would be the same. They RHD GMH assembled Chevs with column shift manual used a crossover arrangement. I've still got a few setups and boxes up on the mezzanine off RHD '57 Chev 6cyl 3spds. I also have a RHD '55-'57 Chev V8 3spd bellhousing at home, and I assume it was done the same as the box was the same AFAIK.
Premier 350 Offline
#5 Posted : Sunday, 9 September 2012 11:09:31 PM(UTC)
Premier 350
Good point, HK1837. I hadn't thought of the LHD to RHD side of the
equasion.
Thanks for posting,
Chris
