mackv8 Offline
#1 Posted : Sunday, 7 October 2012 6:08:57 AM(UTC)
mackv8
Hi all.
Need help with a VS Statesman speedo not working, it started to fluctuate then dropped to zero for a few minits, then came good, for 900 odd KM, then it started to play up and stopped, i don't if the distance was still working as the car is 800 Kays away from me at the moment tomorrow i will get more info, Any one have any idea's at the moment? Thanks mackv8.
looking for an ex ambulance based on the hj/x/z 2 tonner see photo
and collector of all things ambulance police fire and the odd hq to wb parts
#2 Posted : Sunday, 7 October 2012 6:36:12 AM(UTC)
If it's also giving you a "check engine" light, then odds on it's the speed sensor.
If the distances in the odometer & trip computer are still working correctly, then the fault is in the speedo (gauge) itself.
crowe Offline
#3 Posted : Sunday, 7 October 2012 7:23:50 AM(UTC)
crowe
Have the same problem. I just thump the dash!!! Only happens about 2x a year. But I need to pull it out to replace illumination globes so will check all joints etc.
#4 Posted : Sunday, 7 October 2012 10:14:26 AM(UTC)
be the drive gear on the speedo is broken it is common the gear is termed the suicide gear because it is designed to fail.
new gears are available and not that hard to fit but a bit fiddly.
mackv8 Offline
#5 Posted : Monday, 8 October 2012 7:52:47 AM(UTC)
mackv8
Ok some more info when the speedo went out the speed warning still worked.
Tapping of the front of the dash front made no difference.
It was hot in side the car both time's it went out,parked all day in the sun.
This morning it was working ok.car only did around 20 km to day.
Will see what happens tomorrow will be doing about 850 km.
mackv8 Offline
#6 Posted : Tuesday, 9 October 2012 9:34:41 AM(UTC)
mackv8
"check engine" light did not come on.
did 900 km today it worked the whole time.
mackv8 Offline
#7 Posted : Monday, 19 November 2012 6:57:34 PM(UTC)
mackv8
More on speedo problem, Yesterday car in sun most day very hot in car,drove of no speed reading every thing else working ie cruse,trip meter, distance traveled working, put air con on cold after car cooled right down speed traveling came back 15 km traveled so will be getting fixed and let all know what is was.
mackv8 Offline
#8 Posted : Monday, 1 December 2014 8:27:43 PM(UTC)
mackv8
bit late but car got a brand new speedo head. all good now.
This page was generated in 0.097 seconds.
