#1 Posted : Tuesday, 6 June 2006 2:29:04 AM(UTC)
I am going to buy an engine and what to run it onstraight gas. What do I need to change engine wise if anything? What cam is used or different from a normal mild cam? Is a normal carby OK? What compression ratio should I be looking at?
Any other info appreciated
Make mine a Holden with the lot !!!
#2 Posted : Tuesday, 6 June 2006 2:33:34 AM(UTC)
Sorry more info
This is going to be a chevy big block for gas
#3 Posted : Wednesday, 7 June 2006 4:48:38 AM(UTC)
Hardened seats, 11:1 compression and recalibrated dizzy if straight gas. Less than 9.5:1 and a spark map compromise if you want to run dual fuel. You can buy a cam that will suit either fuel, but there will be an optimal one for straight LPG.
#4 Posted : Wednesday, 7 June 2006 5:58:35 AM(UTC)
straight gas will also mean the end of your carby.
a straight gas carby is required.
Gas research carbies are good, and gain 10-30% in power of petrol.
VN Calais, V8 Auto, Blown etc etc.
Air con, Electrical, Car audi
#5 Posted : Wednesday, 7 June 2006 5:42:23 PM(UTC)
Thanks for the replies and info.
This page was generated in 0.124 seconds.
