hollywood Offline
#1 Posted : Friday, 7 December 2012 2:01:10 AM(UTC)
hollywood
hi guys, just wondering if anyone can decode this rochester number?
it is 29282 ZB 0799. cheers.
#2 Posted : Friday, 7 December 2012 2:25:10 AM(UTC)
HT 308 auto. Almost certainly off an earlier HT Brougham.
How are the Foo Fighters going?
hollywood Offline
#3 Posted : Friday, 7 December 2012 2:49:06 AM(UTC)
hollywood
thanks for the reply. Is there such a thing as a list of rochester id numbers for specific model Holdens from HK through to VL? If so where do you find such a thing? Cheers.
To answer youre question. IN hiatus at the moment!!
#4 Posted : Friday, 7 December 2012 2:53:31 AM(UTC)
No there isn't such a list in circulation that I know of. I've been compiling my own as have others based upon original cars recorded over the last 20 odd years. But mine is far from complete. Pretty good for Holden and Statesman 308 but not so good for Commodore VB-VL.
hollywood Offline
#5 Posted : Friday, 7 December 2012 8:34:21 PM(UTC)
hollywood
so are you saying you have a complete list from HK to HZ??? I have a list of my own that ive been trying to compile & fill in the gaps. when i think im close then I find another number that throws it all out. Maybe we can combine lists to sort something out?
#6 Posted : Friday, 7 December 2012 8:54:34 PM(UTC)
I've got most of HK to WB for 327, 350 and 308 and blue 253 to about 1983. There are a few odd ones along the way as well where broadcast sheet codes are missing or even the 70 missing off the front of the carby number like the one you quoted. There are a couple I have recorded that are off a 308 that I haven't yet nailed to a vehicle range, the one i'm thinking of is when the carb used on HX/LX/HZ changed from 17057294 to whatever they changed to and the application of the replacement carbies.
Happy to combine, PM me some info so I know who i'm working with!
GTS350-4play Offline
#7 Posted : Tuesday, 1 January 2013 3:42:15 AM(UTC)
GTS350-4play
Could you guys please share those numbers as I'd like to try and reinstate a carbie for my HQ 350. There are a half a dozen or so advertised on gumtree at the moment. Is it a 7041211?
Motor on now and reject ovals.
#8 Posted : Tuesday, 1 January 2013 4:10:02 AM(UTC)
I'm pretty sure yours should be 7041283 followed by ZH.
#9 Posted : Tuesday, 1 January 2013 9:48:06 AM(UTC)
GTS350-4play
Thanks once again "Good Taste Man" It'll give me a mission in this little lag period.
