delaney1988 Offline
#1 Posted : Thursday, 31 January 2013 8:50:49 AM(UTC)
delaney1988
got a 179hp motor in a lj 4 door that will not start. any sugestions what it could be
delaney1988 Offline
#2 Posted : Thursday, 31 January 2013 8:56:51 AM(UTC)
delaney1988
we had the car out on Saturday out cruzing. had it sitting at 7000rmp in third gear bout to change into 4th.
and the motor made a ping sound then just shut down. got the car back homeand done afew tests on it.eg got spark, fuel. done a comp test sitting on 100 pound over all 6. lifters and push rods are fine. the dissy gear is fine. the only thing I can put it down to is. with the motor at tdc on number 1 the rotor button is pointing past no1 on the cap. could that mean we have striped the timming gear on the cam sharft??? anyhelp would be good
delaney1988 Offline
#3 Posted : Thursday, 31 January 2013 5:44:59 PM(UTC)
delaney1988
Im sure someone can help
#4 Posted : Thursday, 31 January 2013 5:51:26 PM(UTC)
I does sound like the timing gear. If you crrank the engine over does the rotor button turn?
#5 Posted : Thursday, 31 January 2013 5:55:44 PM(UTC)
It must be turning, otherwise he would have no spark or fuel.
It could just have jumped a tooth on either the cam gear or the distributor drive gear.
BTW, 7,000 rpm is serious revving for a street Holden 6.
HTGTS1969 Offline
#6 Posted : Thursday, 31 January 2013 8:39:39 PM(UTC)
HTGTS1969
.... and in 3rd gear most likely a considerable speed.
Edited by user Thursday, 31 January 2013 8:40:15 PM(UTC)  | Reason: Not specified
Monaro - Move ahead of your time
delaney1988 Offline
#7 Posted : Thursday, 31 January 2013 9:09:50 PM(UTC)
delaney1988
Yes rotor button dose turn.
Utility8 Offline
#8 Posted : Thursday, 31 January 2013 10:13:59 PM(UTC)
Utility8
If you reckon you've got comp, spark & fuel...start from scratch.
TDC on No.1 comp stroke.
Move distributor to get rotor on No.1.
Then try for start up.
At a rough guess.....150k's???
Perhaps have your tacho calibrated too.
Edited by user Thursday, 31 January 2013 11:16:08 PM(UTC)  | Reason: Not specified
utility8
delaney1988 Offline
#9 Posted : Thursday, 31 January 2013 11:15:10 PM(UTC)
delaney1988
Thanks everyone for the help going to start from scratch like
