#1 Posted : Tuesday, 16 April 2013 10:39:35 AM(UTC)
what is needed to convert black carby 6 cyl to v8, and add power steering.
Also is it necessary to change floor pan to go manual to auto?
I know pedals have to change.
thanks
#2 Posted : Tuesday, 16 April 2013 4:44:59 PM(UTC)
Hi John,
An easy task - as long as you take it step by step & cover everything.
Floorpan is identical. The insert plate for the shifter changes per trans (no difference between 6 & 8 versions). All VK trimatic shifters are the same, regardless of 6 & 8.
Auto pedals are the same for 6 & 8, but manual ones are different for 6 & 8 - you need to make sure you get the right type. You will need to sort out reverse & inhibitor wiring - there's a 4-pin plug beside the shifter. Pink & green are reverse. The other 2 are the inhibitor, and are simply looped together on manuals.
V8s have 4 wheel disks, so you'll need them, and the right booster & master cyl combo for it.
Front brakes are identical.
Diff is bigger (the old "10-bolt" Sals - 190mm ring gear) and you'll need a V8 tailshaft (bigger uni joints) to match the diff & trans you decide to run.
VK wiring is an absolute mess compared to other models. As it's an orphan as far as wiring, to be plug-n-play you will need to source a VK V8 engine harness. No other model will fit the connections.
If you can't find one, you can use a donor 6-cyl harness, and create your own V8 one, but it's a tedious task.
VK V8s also ran an in-tank electric pump, but earlier ones didn't. Unless you want to wring it's neck, the original fuel system's mechanical pump, as used in VB-VH V8s, will be fine - and allow you to re-use the VK tank - as yours was a carby 6.
You will need a VB-VK V8 radiator & hoses (later ones don't fit). If the VK has A/C, then the clutch fan & shroud are the same. Also, VK V8 & 6 ran the A/C compressor in a similar spot, so you can leave it all intact & just mount the compressor onto the VK V8 bracket (VK & VL have a bracket unique to those models, that allow the sanden TR70 compressor to bolt down onto it).
The best solution for you would be to buy a complete VK V8. Even if it's a sedan, you can still use most parts in a wagon, and vice versa. Diff & fuel tank are the only differences.
Power steering is a little easier.
Early models ran a different set of spacings for the rack mounts between power & non-power racks, but this was consolidated by VK, so all you need is the rack, lines, pump, bracket & pulley.
VB-VL V8s had mandatory power steering (with the exception of a rarely ticked Police delete-option), so these parts are common.
You can only use a VB-VK power rack in a VK, as they changed the design from VL onwards. I prefer the VL/VN rack in an early car, but this requires changing the engine crossmember to a VL-VS V8 one (different to earlier models, and different to VL 6 & VN-VS V6).
Everything bolts up, but the lines from a VL will need to be used for a VL rack. If you get a VN rack (slightly different in the lines to a VL, but much more commonly available) you will need the ends of the pipes, then get a custom set of hoses made for it.
I'm sure you'll have more questions, so keep asking when you come across something you're unsure of.
Dr Terry Online
#3 Posted : Tuesday, 16 April 2013 5:44:17 PM(UTC)
One item not mentioned Mick, is that to be 100% emissions legal, you will need a VK or later 5.0 litre V8.
Any Blue/Red 5.0 or any colour 4.2 V8 will not be Kosher.
#4 Posted : Wednesday, 17 April 2013 4:23:08 AM(UTC)
Very true Terry.
You could get away with a blue 308 painted black if it's an '84 VK, as the engine number prefix is still VT.
witcheshollow racing team Offline
#5 Posted : Thursday, 18 April 2013 5:32:48 AM(UTC)
Gday Guy's Im in the middle of making some changes in a VC sedan but I keeping the 6 (to expensive to rego an 8 in QLD) so some of the points are helpful in this thread but would like to clear up a couple of things.
1- "Auto pedals are the same for 6 & 8, but manual ones are different for 6 & 8 - you need to make sure you get the right type." How do you tell the difference between 6 and 8 manual pedals? I am converting from auto to manual.
2- " Even if it's a sedan, you can still use most parts in a wagon, and vice versa. Diff & fuel tank are the only differences." I have a disc rear out of a VH V8 wagon that I was going to fit to the VC 6 sedan (in-case I decide to do a V6 conversion later) what is the difference between sedan and wagon diffs ??
3- "Early models ran a different set of spacings for the rack mounts between power & non-power racks" My VC has non-power rack so to fit a VH power steering from a 6 cylinder VH, So I have to change the K frame as well for the power steering rack to fit ??
Cheers Barry
"Such is life"
Dr Terry Online
#6 Posted : Thursday, 18 April 2013 7:58:27 AM(UTC)
Cheers Barry
Hi Barry. All good questions.
1. The pedals vary in the way they are mounted & the actual lever ratio. The only way to check is to put them side-by-side. Mick might have some more to add.
2. The wagon rear axle is different in 2 ways. Firstly the track (wheel to wheel distance) is slightly less for a wagon & the lower shock mounts are also different.
3. The VB, VC & early VH mount their manual racks at a different angle & lower down. If you fit power steer to any of these early Commodores, you need to fit the later (or power steer type) front crossmember.
#7 Posted : Thursday, 18 April 2013 4:25:29 PM(UTC)
Hi Barry,
The V8 clutch pedal has an additional section welded into it, to move the pivot point out.
The top of the V8 pedal is also a T shape, where a 6 is almost straight.
A picture tells a thousand words:
