HGV8 Offline
#1 Posted : Sunday, 5 May 2013 3:14:02 AM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
Engine casting date Feb 1969, 1st registered 30th May 69.
http://www.ebay.com.au/i...3c6&_uhb=1#ht_500wt_1167
j.williams
castellan Offline
#2 Posted : Monday, 6 May 2013 7:12:52 PM(UTC)
castellan
Would be go to know the real date of the block most probably the prefix B is an E and it would be a early May cast block i would think.
#3 Posted : Monday, 6 May 2013 7:46:46 PM(UTC)
I've seen 308 and 253 blocks with numbers lower than that cast back in 1968, so Feb isn't out of the question.
adam PERTH Offline
#4 Posted : Sunday, 15 December 2013 11:24:29 AM(UTC)
adam PERTH
when did the timing cover change with respect to the timing marks on the holden V8? - simular to the chev which changed in 1967
