2 Pages<12
#21 Posted : Wednesday, 26 June 2013 8:42:51 PM(UTC)
It is missing digits from the VIN and the paint code should be 11905.
You cannot tell from numbers what it was engine and box, only that it was a V8. Having the Saginaw hump means 253 or 308, it looks to be not all that early in HT so it could be 253 or 308 manual (early on in HT all manual V8's were 253 apart from one or two *(basiclaly bugger all) 307 manual).
If it has the 10-bolt hump it'll be a 308. If it doesn't it was a 253.
All assuming it is the original shell for the tags.
Paul smith Offline
#22 Posted : Wednesday, 26 June 2013 9:08:56 PM(UTC)
Paul smith
Ok thanks. Yeah sorry typo on paint code and photo of Id tag is cut off. So paint and interior I think is verado green and houndstooth interior??? Thanks again.
Paul smith
Paul smith Offline
#23 Posted : Wednesday, 26 June 2013 9:12:12 PM(UTC)
Paul smith
Also how do you check chassis and vin numbers line up.
Paul smith
#24 Posted : Wednesday, 26 June 2013 10:23:08 PM(UTC)
1194 is Verdoro Green Metallic and 18X is Sandlewood & Black vinyl.
You cannot tell that the chassis and VIN align without having heaps of cars recorded to then state that they appear to align. If you get the VIN I can get it checked for you to make sure that they should belong together.
I'll also need the body number off the plate with teh TRIm and PAIBT lines on it to check if it should belong with the others.
Paul smith Offline
#25 Posted : Wednesday, 26 June 2013 10:41:05 PM(UTC)
Paul smith
Ok cheers numbers off plate
80837TR
718-H5
Trim 1194-18X
Paint 567-119605
Other plate
80837 TH 614095
Firewall HT 307135
Paul smith
#26 Posted : Wednesday, 26 June 2013 11:27:15 PM(UTC)
I'll see what I can find out. The 5 on the end of the chassis number is an S.
Paul smith Offline
#27 Posted : Thursday, 27 June 2013 12:36:07 AM(UTC)
Paul smith
Ok cheers yes it is an "S"
Paul smith
#28 Posted : Thursday, 27 June 2013 8:59:14 PM(UTC)
80837TR
718-H5
Trim 1194-18X
Paint 567-119605
Other plate
80837 TH 614095
Firewall HT 307135
Answer is all plates and chassis number pretty much align OK. Car is way to late to be a 307, so it is either a 253 or 308 with M21 if it has the shifter clearance pressing in the tunnel. The rear floor and fuel tank hump will give it up as to whether it is a 253 or a 308.
Paul smith Offline
#29 Posted : Friday, 28 June 2013 1:59:50 AM(UTC)
Paul smith
Thanks very much for the info appreciate your help. Now I've just got to get him down to a credible price.
Paul smith
Guest (12)
2 Pages<12
