Rhys Offline
#1 Posted : Monday, 3 June 2013 8:22:38 PM(UTC)
Rhys
Would anyone know the best way to fix this problem - I have a HQ with factory air and water in the plenum is making its way into the front passenger side footwell.
There is no rust in the plenum, the water is entering from around the outside edge of the plastic duct before it has a chance to go out through the drain hole at the end of the plenum. How were these fresh air ducts sealed from the factory? If only by foam, is this best replaced or would it be best to put a sealant between the round duct the the plenum? Can it be done in-situ or am I best off pulling the duct out?
Edited by user Monday, 3 June 2013 8:55:20 PM(UTC)  | Reason: Not specified
#2 Posted : Monday, 3 June 2013 9:30:52 PM(UTC)
The duct itself had a white foam seal gasket, sort of like double sided tape but not sticky. It normally remains fixed to the plastic when you remove it.
All I can think is that seal has died over time, or possibly if the "factory" air was not original to the car, whomever put it in may have only used 2 x screws (as the non A/C fresh air duct only uses 2 x screws) - it may need a new seal and an extra screw.
When you remove the duct put your hand up there and remove any dirt or leaf matter, and clean it all out properly. You may find the foam seal around where the duct joins the evaporator housing will fall apart too.
Rhys Offline
#3 Posted : Tuesday, 4 June 2013 12:30:39 AM(UTC)
Rhys
Thanks Byron, I'll give that a go. I suppose no one has started reproducing this foam gasket yet - might have to make one.
Premier 350 Offline
#4 Posted : Friday, 7 June 2013 1:44:26 AM(UTC)
Premier 350
For the gasket- try Raven Products- they make draught foam tape in
various sizes & densiy.
Your local hardware store should stock it.
Rhys Offline
#5 Posted : Friday, 7 June 2013 6:42:31 PM(UTC)
Rhys
Thanks for the info Premier 350, sounds like the way to go.
Mr Sir Offline
#6 Posted : Sunday, 9 June 2013 6:23:00 AM(UTC)
Mr Sir
I have just done this recently to my WB the best way is remove the vent (I had the dash out for other reasons) I removed the vent completely because the foam gasket is old and dry and the foam seal going to the heater box will probably ,if it hasn't already will just fall apart. You will probably find that when you remove the vent that there are small rust holes in the plenum that are also allowing the water in. I used sicaflex on the vent appying a nice thick bead and to replace the foam at the heater box I went to an upholsterers buying some foam and cut out the foam to match the vent to heater box sticking it to the vent with sicaflex. The rust holes I just sealed up with sicaflex after I cleaned them out by poking around with a screw driver.This just a budget build to get the kid on the road ,He can do the proper rust repairs when he starts to earn his own coin. The draught foam tape I used on the rear of my dash vents to seal in the ducting tubes the tape size was 12mm wide x 1mm - 3mm gap. I also used this inside the vents to hold them in the desired position and to stop them flopping around. The vents are now as good as when they came from the factory.Note do not use clear silastic to seal stuff, apparently it causes rust, so I've been told. Cheers MS
Rhys Offline
#7 Posted : Tuesday, 18 June 2013 9:27:21 AM(UTC)
Rhys
Thanks for the info MS, good advice. I pulled it apart on the weekend and found that there were 3 screws holding it up, but not evenly spaced - see photos below. I was going to renew the foam gasket but the old one seemed OK and I figured a new one would start leaking again eventually with this screw setup so I decided to just clean the gasket and apply a bead of windscreen sealant around it. Good as gold now, no leaks. It looked like it should've had 4 screws, but if there was one up near the drain tube it'd be quite tricky to get to. Also no provision in the duct itself for the 4th screw so obviously a poor design. I think later models with air had 3 screws but were all 120 degrees apart (?), which would've held it to the plenum much tighter.
#8 Posted : Tuesday, 18 June 2013 5:48:10 PM(UTC)
3 x screws are correct for factory air fresh air duct and also for the driver's side blacnking plate. The non-A/C vents only use two of those 3 screws.That is pretty clean up under there, the electrostatic red lead primer got in there good.
