phill Offline
#1 Posted : Friday, 21 June 2013 7:13:55 PM(UTC)
phill
Hey Guys, I think the master cylinder has a leak in my XB,
I went for a drive the other day and at times it sounded like an air leak down near the foot pedals when braking, when I drove into the driveway to park it, I had my foot on the brake, turned off the motor, then the air stopped and the brake pedal went hard like always,
How can I check if the brake booster is ok before I pull it out? and could it be some thing else?
Cheers Phill.
#2 Posted : Friday, 21 June 2013 7:28:32 PM(UTC)
Phill,
If your brake booster sucks air in when you put your foot on the brake this is normal. However if it is constantly sucking air in with the engine running and your foot on the brake then you have a split diaphragm in your booster and it's time for a new one.
phill Offline
#3 Posted : Monday, 24 June 2013 8:18:35 AM(UTC)
phill
Hey Jim, thanks for your reply, cheers Phill.
gcg2503 Offline
#4 Posted : Monday, 24 June 2013 10:04:24 AM(UTC)
gcg2503
Just discovered today that I have the exact same problem in my Landau
Hissing sound from the pedal area....time to rebuild my booster (that was already rebuilt)
Grrrrrrrrrrr
phill Offline
#5 Posted : Tuesday, 25 June 2013 7:43:54 PM(UTC)
phill
Those dam black cats crossed our paths, or did we walk under the same ladder, lol, I feel your pain brother! It's in the middle of my head, owell,,, could be worse without brakes, :-)
Guest (5)
This page was generated in 0.211 seconds.
