David 67HR Offline
#1 Posted : Tuesday, 9 July 2013 1:16:00 AM(UTC)
David 67HR
Looking for a Holden 9 port Yella Terra Head
Edited by user Tuesday, 9 July 2013 1:17:31 AM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 9 July 2013 3:02:45 AM(UTC)
What type? High or Low comp? Early (ie 149-186) or late (173/202)?
David 67HR Offline
#3 Posted : Saturday, 13 July 2013 6:35:02 PM(UTC)
David 67HR
149-186 High is preferable,
#4 Posted : Saturday, 13 July 2013 8:05:50 PM(UTC)
Those are different heads, 149HC head is a closed chamber, 179 and 186HC heads are an open chamber head (and is actually the low comp 149-161 head). You can put the H head onto a 186 but you end up with XU1 type compression (that is basically what and XU1 engine is ie a 186 with a 161H head).
David 67HR Offline
#5 Posted : Saturday, 13 July 2013 11:41:11 PM(UTC)
David 67HR
I see, thanks for the info. So sounds like I need a 161H to put on my 186, which will run a 223 Clive cam, a 2 Barrel Carb and Pacemakers with a 2 inch exhaust......where do I get one? I finally found a nice HR Premier and that's what the engine is going into.
Edited by user Saturday, 13 July 2013 11:46:40 PM(UTC)  | Reason: Not specified
#6 Posted : Sunday, 14 July 2013 1:24:00 AM(UTC)
Just keep an eye on Ebay. That combo will be around 10:1 or possibly more if the head is shaved.
Here's one. It says 202 but it is a 161H head.
http://www.ebay.com.au/i...19df1f07f9#ht_178wt_1170
#7 Posted : Sunday, 14 July 2013 1:25:44 AM(UTC)
David 67HR Offline
#8 Posted : Sunday, 14 July 2013 4:06:12 AM(UTC)
David 67HR
I bought 1 off ebay 2 months ago and it has worn exhaust valve seats,
even the one they want $950 looks like some of the same problem
#9 Posted : Sunday, 14 July 2013 6:28:59 AM(UTC)
Just get new seats put in, then you can run ULP without additive.
David 67HR Offline
#10 Posted : Sunday, 14 July 2013 7:43:49 AM(UTC)
David 67HR
Do you mean put new inserts in?
#11 Posted : Sunday, 14 July 2013 7:27:36 PM(UTC)
Yes, hardened seats like they do for LPG.
David 67HR Offline
#12 Posted : Monday, 15 July 2013 11:02:05 PM(UTC)
David 67HR
What about the 149 YT head on ebay, I can get it for $500
#13 Posted : Tuesday, 16 July 2013 12:29:32 AM(UTC)
Didn't you say you had one? 149 and 161 H heads should be the same basic thing.
David 67HR Offline
#14 Posted : Tuesday, 16 July 2013 12:35:10 AM(UTC)
David 67HR
Yes I do but the 149 has had full reco and extra porting and flow tested at 270hp
#15 Posted : Monday, 29 July 2013 8:57:13 PM(UTC)
You'll want a pretty serious n/a 202 to get 270hp, triples, XU1 spec cam etc.
David 67HR Offline
#16 Posted : Sunday, 11 August 2013 1:06:46 AM(UTC)
David 67HR
Yes you are correct, sounded to dodgy so I rang Eddie at HSD and he has built me a stage 3 Head for $1300. Also got a Cam and lifters from Clive's Cams. Both fantastic blokes to deal with
Edited by user Sunday, 11 August 2013 1:08:40 AM(UTC)  | Reason: Not specified
