#1 Posted : Friday, 12 July 2013 6:00:53 AM(UTC)
I'm putting a Borg Warner diff out of a EL wagon into my HQ tonner
Can anyone tell me if I'm able to put my HQ Salisbury axles into the Borg Warner diff?
The EL diff is a 78 series, the HQ diff is a tonner diff, so they both should be 28 spline, axle bearings should be the same, the only drama I can see is maybe length, the HQ housing is around 10mm longer, but loosing 5mm of length from each axle shouldn't be a problem
Does anyone know if its possible??
#2 Posted : Friday, 12 July 2013 6:22:31 AM(UTC)
HQ axles are the same length either side. Ford axles are long & short.
#3 Posted : Friday, 12 July 2013 6:31:36 AM(UTC)
Thanks Terry
Looks like I'll have to get the axles re drilled then!
This page was generated in 0.022 seconds.
