Roger Ramjet Offline
#1 Posted : Wednesday, 31 July 2013 7:25:13 AM(UTC)
Roger Ramjet
Hi I am currently rebuilding the motor in my HG, it is an original factory 253 and has the original block still in it. The bottom end had a kit put through it a few years ago however the heads are shagged out.
I know everyone says to rip out the 253 and put a 308 in it however its a matching numbers car and if i ever sell it i can change the manifold and carby over and she will be back to pretty much standard.
I am having the heads redone (nothing silly - just std) and am putting a CM313 cam in it and a 4 BBL edelbrock performer manifold and holley 465, anyone got any idea of how much power this will produce? also if I add extractors what will this do to it also.
#2 Posted : Wednesday, 31 July 2013 6:25:46 PM(UTC)
You'd probably be better off with an original HT-HJ 308 manifold and early Quadrajet, will look original and work as well as the other combo.
castellan Offline
#3 Posted : Thursday, 1 August 2013 12:01:46 AM(UTC)
castellan
I have no idea what cam that is, a bit bigger than std ?
You need a single 2 2/4 free flowing exhaust at least.
A good std HG 253 makes about maybe 150 net HP i think and a 308 = 196 net HP.
Edited by user Thursday, 1 August 2013 12:11:50 AM(UTC)  | Reason: Not specified
#4 Posted : Thursday, 1 August 2013 2:22:10 AM(UTC)
A CM313 cam will be too big for a street driven HG 253, especially if it's an auto.
The listing I have says it has 233 duration @50 thou & .495" lift, plus they describe it as a 'stage 4'.
I'd stay with a stock cam & as HK1837 said use a Q-Jet & a stock hQ type inlet. It will be both economical & torquey & not drive like a pig.
#5 Posted : Thursday, 1 August 2013 2:29:08 AM(UTC)
I'd also swap to a HEI dizzy and coil, can be done without any major mods and looks relatively stock.
