rageng Offline
#1 Posted : Wednesday, 4 September 2013 7:21:48 PM(UTC)
rageng
rare spares sell the weld in flute sections for gaurds was just wanting to know the dimensions for placement of the flutes into the gaurd thanks
peter_flane Offline
#2 Posted : Thursday, 5 September 2013 12:44:05 AM(UTC)
peter_flane
I need to know too please.
monman71 Offline
#3 Posted : Wednesday, 11 September 2013 11:41:57 PM(UTC)
monman71
Do you still require and measurement? , I can get them when I get home. Cheers
peter_flane Offline
#4 Posted : Thursday, 12 September 2013 4:32:45 AM(UTC)
peter_flane
Yes please. Distance from mid body line to top of top flute, and distance from back edge of guard to back edge of top flute and bottom flute.
monman71 Offline
#5 Posted : Thursday, 12 September 2013 7:03:00 AM(UTC)
monman71
Ok, from crease line to crease on top flute 42 mm, from the door gap at top to slight crease on flute 57 mm if you continue to the cut out far point approx 171 mm, bottom point 58 mm continue 170mm (90 degrees off flute cut out, hope this help and can be understood. Cheers
peter_flane Offline
#6 Posted : Thursday, 12 September 2013 8:01:32 AM(UTC)
peter_flane
Makes sense
rageng Offline
#7 Posted : Thursday, 12 September 2013 7:19:38 PM(UTC)
rageng
thank you for the dimensions greatly appreciated.
This page was generated in 0.221 seconds.
