hk350 Offline
#1 Posted : Monday, 4 November 2013 10:06:32 AM(UTC)
hk350
Hi fellas, just had my hk 307 carby overhauled and just need to check if the right parts have been put back on it. The guy that did it was absolutely useless and his workshop was a nightmare (only seen once he was nearly done)and I have a feeling he's put parts from another carb on it. The bits i'm concerned with are (I think)the fast idle cam and choke rod. I've attached a pic. Do these parts look like the correct ones?
Cheers, Glenn.
[/URL]
Edited by user Monday, 4 November 2013 10:11:37 AM(UTC)  | Reason: Not specified
Premier 350 Offline
#2 Posted : Wednesday, 6 November 2013 12:40:10 AM(UTC)
Premier 350
It's a Rochester 2GC isn't it? How about checking with some US based
forums? The 2GC was used in many applications.
Sorry, thats all I can suggest.
bazza30555 Offline
#3 Posted : Thursday, 14 November 2013 8:00:05 AM(UTC)
bazza30555
I will check mine and let you know
bazza30555 Offline
#4 Posted : Friday, 15 November 2013 6:46:24 AM(UTC)
bazza30555
Both the parts are the same as mine even the number. Cheers John
hk350 Offline
#5 Posted : Friday, 15 November 2013 9:18:29 AM(UTC)
hk350
Thanks John, you're a champ.
