Ayios Offline
#1 Posted : Wednesday, 27 November 2013 10:07:37 AM(UTC)
Ayios
Hi Guys
Does anyone know if factory VN HSV extractors will fit into a HT Holden with out any issues?
The other option is standard cast VN exhaust manifold.
Anyone used either option?
______________________________________
Speed has never killed anyone, suddenly becoming stationary... thats what gets you
#2 Posted : Wednesday, 27 November 2013 7:05:38 PM(UTC)
The VN ones fit in HQ-WB but the O2 sensor socket has to be plugged and a new one put in. I think its the lower control arm rear mount on the passenger side that the O2 sensor hits, but HK-HG are different in this area so i'm not certain how it'll go. In my HZ tonner I used VR-VS cast manifolds, just use V6 plates as they are smaller and easier to clear the sump.
edelbrock1 Offline
#3 Posted : Wednesday, 27 November 2013 9:15:13 PM(UTC)
edelbrock1
I used VS cast manifolds in my HT. Had VS HSV headers as well to go on, but the lazy exhaust fitter could not be bothered fitting them. I can see no reason why they would not fit. But I sold the car before I got the opportunity to see if they did or not.
But the cast manifolds fit without any issues at all.
Ayios Offline
#4 Posted : Thursday, 28 November 2013 7:45:35 AM(UTC)
Ayios
Thanks for the info guys, I figured the cast manifolds will fit but am hoping the HSV ones will as they flow much better.
