Can anyone shed some light on this? HK/T and HG trim appear to be the same:
Here are all the numbers, and you will see why I am confused! The cut-outs fit a HG grill neatly, so I guess they are the HG.
Left unit: 7433935 chrome 7434078 black holden 1 272, rd no. 49880LH
Right unit: 2814214 chrome, 2914216 black (HG), then on the other side of the top of the right hand unit it has: 7433936 chrome, 7434080 black (HK/HT) rd no. 49879 RH, holden 1 272.
Both units have identical HG grill cut-outs at the top! The right hand unitwith 2 sets of numbers is in better condition than the left, could this be a later replacement type unit to cover all three models? The units I put on my car (HG ute) were mint, and I had to modify one of them to suit the grill, so this must have been a HK HT one?
You are correct that HK/T are the same, and HG is different. There have been NOS HG ones around for a while, but HK/T are more valuable and rarer. The 74 prefixed numbers are HK/T as you say, and the 28 numbers are HG. The ones with just the 74 numbers a |
Thanks for that Byron, so it appears there is a HK/T casting; a HG casting; and a HK/T/G casting - is that correct? Can you tell me what exactly is the difference between a K/T and a G one?
Do you know where any HG L&R NOS trims are available?
Cheer
I should clarify that everything after the first line in the OP is from a seller of these trims, so I don't understand myself about the cutouts he refers to
