having problems engine check light and traction lite coming on scan tool said front oxy sensers playing up so replaced them both still came on after a week replaced maf senser and vacuum senser on inlet manifold all vacuum hoses seem ok also had one crank senser replaced 6 months ago anyone got any more ideas is it a computer prob or maybee abs module it a 2006 6 litre model thanks
Simple test you can do - check your battery voltage. Had similar issues in the in-law's caprice when the alternator went flakey. Ended up diagnosing it by hooking up a multimeter & checking the voltage when the problems were occurring - anytime it dropped under 11.0V the dash lit up like a Christmas tree.
The ABS module will cause issues with anything on the can-bus (traction, ABS, and even the aircon can stop when it's playing up).
Best bet is to get in contact with Dr Terry, so you can order a replacement module from him. |
Ok thanks will check that first thing how do I get thru to doctor Terry's business ? Thanks commodorenut you have helped me out more than once cheers
Mick sent email to terry thanks again
No probs. Otherwise you can call his business on 02 9644 2888 |
All under control, Laurence rang me today, & he's checking a few things out that we went thru.
Thanks Mick.
Dr Terry |
Just looking for any new ideas on this problem dr terry is helping but I am desperate to sort this out been a month now and my partner lost her job last night with a uncompromising boss over transport to ever changing work shifts . I canot find any vacuum leaks in hoses am thinking its unlikely that the inlet manifold is leaking but maybe? Or maybe the computer that runs trans because of way it is shifting if anyone has a idea I am up to try it cheers
