My Holden Astra does not sound when the turn signal is activated. How to fix it?
You are a member of these groups:: Moderator, Registered
It's Holden Astra City 2001
Is there anything else I have to add?
Sorry, I have been a little busy for the past few days.
TS Astras use a similar electronic flasher relay to VT Commodores, they also suffer from this.
Just replace the relay, it should be underdash on the driver's side.
the problem is that...there is nothing :)
