jayHK69 Offline
#1 Posted : Monday, 21 July 2014 11:11:51 PM(UTC)
jayHK69
hi all,
on my hk the driver side reverse light is not working,passenger side is fine,the driver blinker works fine as well.
i have no power at the plug on the rear harness connector (before tail light harness).
would this point to the problem being in the indicator switch ?
thanks in advance
gm5735 Offline
#2 Posted : Tuesday, 22 July 2014 12:55:34 AM(UTC)
gm5735
Yes. The left and right rear indicator lamps are connected together by a moveable contact in the indicator switch when the switch is in the middle position. If you disconnect the battery and check for continuity (ohms range) between the centre contact at the rear indicator lampholders you should see them connected to each other with the indicator switch in the middle, and disconnected from each other when the indicator stalk is up or down.
For what it's worth checking the earths on the lampholders would be a good idea. Sometimes odd things happen when an earth is missing, with lamp filaments finding paths to earth through other filaments, particularly if the lamps are of different watt ratings. Good luck.
jayHK69 Offline
#3 Posted : Friday, 25 July 2014 7:09:08 PM(UTC)
jayHK69
thanks for the reply gm5735,sounds like i need to get a multi meter
i`m not sure that it`s an earth problem as someone before me has soldered earths from the globe holders & other ends bolted to body
jason
#4 Posted : Friday, 25 July 2014 8:55:32 PM(UTC)
Save your time Jason, you won't need a multi-meter. As gm5735 has said, it will be the indicator switch.
If the blinker works, but the reverse light doesn't, but the opposite reverse light does, then it is the switch at fault 100%, no need to check anything further. If there was a wiring or socket issue, then the blinker wouldn't work.
gm5735 Offline
#5 Posted : Saturday, 26 July 2014 9:44:25 AM(UTC)
gm5735
Agreed. Burnt, bent, broken or otherwise buggered contacts in the switch. Or its full of congealed thick shake from a misadventure at the plastic food factory drive through.
jayHK69 Offline
#6 Posted : Saturday, 26 July 2014 11:45:49 PM(UTC)
jayHK69
thanks again gm5735 & dr5 terry.new indicator switch it is.
cheers jason
jayHK69 Offline
#7 Posted : Sunday, 27 July 2014 6:31:00 PM(UTC)
jayHK69
has anyone used the rare spares indicator switches ? if so how good/bad are they ?
Guest (7)
This page was generated in 0.106 seconds.
