castellan Offline
#1 Posted : Friday, 12 September 2014 7:16:05 PM(UTC)
castellan
What is it that the old steering wheels are made out of, the covering of them.
I think the last was the HZ that came like that but is the FJ the same stuff as the HZ.
Premier 350 Offline
#2 Posted : Tuesday, 16 September 2014 1:38:15 AM(UTC)
Premier 350
Can't help with the material itself, but the HZ was a soft feel wheel,while the FJ was hard.
Bottom line: different materials.
#3 Posted : Tuesday, 16 September 2014 1:49:45 AM(UTC)
Early HJ (1974) was the last of the hard plastic (same as HQ). Changed at the start of (or during) 1975 to the soft wheel.
castellan Offline
#4 Posted : Tuesday, 16 September 2014 7:11:42 PM(UTC)
castellan
Bakelite I thought, but was not sure if FJ type changed somewhat up to the HJ type.
I don't remember the std HX-Z wheel I thought it was the same as the old HJ I must be because it look the same type of deal and the VB came out with a different looking wheel.
All UC torana's had a nice sports wheel I think.
XB falcons had the bakelite then changed to the rubber.
#5 Posted : Tuesday, 16 September 2014 11:39:14 PM(UTC)
UC wheel you are thinking of was the standard HZ GTS/Sandman/SL/E wheel.
