adam PERTH Offline
#1 Posted : Monday, 20 October 2014 12:31:21 AM(UTC)
adam PERTH
i just put a VX motor into a VT (including harness and VX ECU)..
done a few before (VX into VT) but used the VT harness and ECU previously.
now it starts everytime for a second then cuts out and wont run on..
any ideas??
#2 Posted : Monday, 20 October 2014 3:30:48 AM(UTC)
You need to pair the BCM to the PCM, as it's the anit-theft that's cutting in and stopping it.
Or the other option is to send the memcal off to have the VATS removed.
adam PERTH Offline
#3 Posted : Sunday, 26 October 2014 4:32:43 AM(UTC)
adam PERTH
thanks commodorenut,
I borrowed my mates SNAPON Ethos, but I cannot seem to find anything to select ON/OFF to connect PCM to BCM.
any ideas?
adam PERTH Offline
#4 Posted : Sunday, 26 October 2014 4:33:55 AM(UTC)
adam PERTH
also, I selected model as 2001 VX on the scanner, that's correct isn't it?
petaus Offline
#5 Posted : Sunday, 26 October 2014 9:40:18 AM(UTC)
petaus
That's correct adam what ever year it is, it will be in engine, special functions, the link pcm to bcm.
I am not sure if the ethos has the function it might only be a code reader.
I have a snap-on solus but don't use it on the holden as I have a tech 2.
pete
