detective Offline
#1 Posted : Monday, 10 November 2014 4:23:45 AM(UTC)
detective
....g'day all .. just tooling around on the internet this arvo and see that Amethyst Metallic wasn't available on the Monaro's, (which i wasn't aware of) but that also there were two different codes for that colour in 1971....
...this has been a niggle to me for over 35 years as i reckon there always was a very ''washed out'' pale looking Amethyst and a very 'bold'' almost plum looking Amethyst...
...my 1971 GTS 350 has the latter of the two, and i can distinctly recall seeing a lot of HQ sedans back in the day with that awful looking pale colour...but also a couple of the bolder coloured ones sometimes here and there....
...is there a reasonable explanation for this?...i am talking about cars that were original and untouched from way back then....cheers fellas
#2 Posted : Wednesday, 19 November 2014 6:10:53 AM(UTC)
In 1971 as far as i'm aware you couldn't get any metallics on Monaro (which was a Kingswood Coupe essentially). You had to go to Premier/LS and GTS to get metallic paint.
There were MKII colours released in 1972 for Baroda Silver and Phantom Grey so maybe Amethyst was the same? It'd have a different colour combination numbers though and also different Dulon refinish codes. Or possibly the other colour you saw was a styling clinic car for a different shade of the same colour? GMH regularly did this where they showed off various colours. Norm Darwin put photos in Torana Tough, page 141. You can see the 3 x Strike Me Pink styling clinic cars clearly. There is also a photo of a whole line of cars with colour variations, and a BODY plate shown of a car with styling clinic colours, the paint refinish line normally has A, B or C on the end which we think means the 3 x cars with paint variations on them
#3 Posted : Wednesday, 19 November 2014 6:12:45 PM(UTC)
I only have one code listed for Amethyst metallic & no MkII versions mentioned.
What are the 2 code numbers that you have ?
I'm not sure about Amethyst in particular but I always believed that metallics were made avialable for Kingswood/Monaro level cars for HG onwards. Prior to that, they were availble only for Premier/GTS (& above).
#4 Posted : Thursday, 20 November 2014 12:21:23 AM(UTC)
In 1971 Terry metallics were Premier/LS or GTS only on a HQ Holden afaik. It was sometime in '72 that it changed again. GMH regularly did this during the 70's where metallics were and weren't available across all Holdens at various stages.
detective Offline
#5 Posted : Thursday, 20 November 2014 1:42:31 AM(UTC)
detective
...Hi all .. if you google "HQ Holden Amethyst"...it opens up a lot of (mis?)information...
...i'm guessing HK1837 is right regarding the base Monaro not having that colour ??.....cheers fellas
...also there appears to be two versions of the same code...13121/2A001 - and 2A001 metallic...both 1971 colours....?
...BTW .. just checking the paint/trim codes on this one here and it reads...paint 567-13121...trim 1826-18Y....
Edited by user Thursday, 20 November 2014 2:08:47 AM(UTC)  | Reason: Not specified
#6 Posted : Thursday, 20 November 2014 4:46:09 AM(UTC)
I think the 2A001 refinish code will be a modern-ish Berger code. 1826 is the GMH code for Amethyst Metallic and 13121 is the Dulon refinish code. Those are the only ones I know of.
#7 Posted : Thursday, 20 November 2014 5:50:38 AM(UTC)
2A001 is a GMH code for both Dulon and Burger. These codes came in during VC Commodore, after the HH code Berger paint experiment.
Warren
#8 Posted : Thursday, 20 November 2014 7:02:34 AM(UTC)
I've seen them earlier than VC Warren.
#9 Posted : Thursday, 20 November 2014 9:26:45 AM(UTC)
Some of the colours might have pre-dated VC, but that's when GMH literature advises of the changeover, and the active colours at the time were converted over to the new codes (and some of those colours had been around for years).
Earlier VCs still have the old 567-xxxxx and 568-xxxxx codes on them, but the later ones all went to the 1X### and 2X### codes, which were well in place by the 9/81 VH release.
As an examples:
- The first (solid) Red code was Firethorn.
- 2nd (metallic) blue was Atlantis
- 1st (metallic) Green was Malachite
All of these colours were used on other models, and pre-date the VC in some applications (particularly Firethorn) but that's when those codes were born.
#10 Posted : Thursday, 20 November 2014 4:52:40 PM(UTC)
I've even seen them trialled on Chevy trucks around 1978. One particular example was painted 1883 (called Turnpike Red). This was normally 439-15339 for the refinish code (439 is Dulux acrylic enamel), but this example had 1883 for the GMH paint code and HA 4798 for the refinish code. It is by chance a very famous K20 as well.
#11 Posted : Friday, 21 November 2014 1:52:49 AM(UTC)
H colours are the Berger trial colours, as Warren noted above, and these were limited to a handful of colours.
What we're talking about is the change in the numbering system, which brought in the 1x-000-z, with 1 being the type (solid or 2 for metallic) X being the colour family, 000 being the sequential shade number, and z being either (B)erger or (D)ulux.
The old 567/568 numbers that were still in current use during VC were converted over to the new system, and THIS is why there's 2 references for the same colour - it is the same colour, just a different numbering system.
In '88/89 they dropped the B/D suffix.
In 1993/4 they dropped the digit off the front (corresponding with the paint change on VR2).
Prior to VE the codes all changed again, to a completely different system, but this was run in parallel as far back as early VY (and maybe even VX). Thus we still have paints popping up under several codes (eg Heron White, Red-Hot etc) as they carried through both periods.
#12 Posted : Friday, 21 November 2014 3:27:48 AM(UTC)
So 1G 001-D as the refinish code for 1972 would be Torquay Sand in Dulon acrylic?
And 2B 034-D as the refinish code for 3027 would be Spindrift in Dulon acrylic?
These are both on WB's.
#13 Posted : Friday, 21 November 2014 7:28:52 AM(UTC)
Yes, the -D is Dulon acrylic for both.
Torquay Sand was out on early VH (released during VC) but Spindrift wasn't out until VK (and corresponding WB models) although it's number range puts it in '83 as to when it was "approved" so to speak.
You can also date them from the combo numbers - 1972 just pre-dates 1979 which is Venetian Red (first seen in 9/81 VH) and 30** numbers are late VH and all VK onwards (unless they brought back an old colour like Police blue or Tuxedo Black, which retained their combo number from the 70s (or 60s)).
