kiwijeff Offline
#1 Posted : Monday, 17 November 2014 8:59:31 PM(UTC)
kiwijeff
I'd like to run a 9 port red head on my 3.3 blue motor.
Is this doable?
Reason is, I want to run triple Strombergs from a 202.
I found a great finned manifold at Weber Performance, but its for a red head. I don't want to run Webers or SUs, which I can get a manifold for the 3.3.
This engine is in a hot rod, hence the 3 up wright Stromburgs.
Thanks in advance.
#2 Posted : Tuesday, 18 November 2014 12:36:19 AM(UTC)
You can but water holes are in different spots. Stick a red and blue/black head gasket together and you'll see where the holes that are different are. They can be drilled out on the block, many people I have heard just leave the gasket to seal off the unused holes, others drill and tap the old holes and put a plug in them.
kiwijeff Offline
#3 Posted : Tuesday, 18 November 2014 2:39:19 AM(UTC)
kiwijeff
Thank you HK1837.
Sounds like it won't take much work to sort the head out.
May even use a Yella Terra head.
