David 67HR Offline
#1 Posted : Friday, 13 March 2015 5:33:26 AM(UTC)
David 67HR
What are these Stromberg carbies off 23-3019 1 5/32
#2 Posted : Friday, 13 March 2015 11:30:26 PM(UTC)
HR-HG and LC 161 manual according to this site:
http://monarocoupe.com/w...-2-barrel-model-numbers/
#3 Posted : Saturday, 14 March 2015 2:16:06 AM(UTC)
My list says that it's a 1-3/32" carby off 149 & 161 from Nov 65 (HD) to HG & 2250/2600 LC - manual trans only.
#4 Posted : Saturday, 14 March 2015 2:28:02 AM(UTC)
I'd trust Dr Terry's info first before stuff off the 'web!
#5 Posted : Saturday, 14 March 2015 2:40:10 AM(UTC)
I suppose that I should 'fess-up'. It's not 'my' info, I've compiled it from several original Bendix Stromberg parts manuals that I've collected over the years.
#6 Posted : Saturday, 14 March 2015 3:10:20 AM(UTC)
It'd still be heaps more accurate than a 'web list. At least the 'web page is in the ballpark!
David 67HR Offline
#7 Posted : Saturday, 14 March 2015 6:03:26 AM(UTC)
David 67HR
What about 23-3020 1 5/32 what are they off lads
#8 Posted : Saturday, 14 March 2015 8:28:05 PM(UTC)
My list says that it's a 1-5/32" carby off 179/186 from Nov 65 (HD) to HG - manual trans only.
David 67HR Offline
#9 Posted : Monday, 16 March 2015 9:57:30 AM(UTC)
David 67HR
Thanks DR Terry, got a matched pair fully rebuilt for $300
David 67HR Offline
#10 Posted : Tuesday, 17 March 2015 9:35:56 PM(UTC)
David 67HR
What about 23-3014 DR Harry
castellan Offline
#11 Posted : Tuesday, 17 March 2015 9:46:25 PM(UTC)
castellan
23-3020 is a HR-G 186 manual.
23-3014 is a HD-G 186 auto.
gm5735 Offline
#12 Posted : Tuesday, 17 March 2015 10:39:16 PM(UTC)
gm5735
Dr Harry?
Are we talking carbies or budgies?
#13 Posted : Tuesday, 17 March 2015 10:50:57 PM(UTC)
David, when you say that you purchased a pair of these, did you mean two 23-3020 or 23-3019 ? Are you intending to run the two on one car, using an X2 manifold or similar ?
If you are, the 23-3020 carbies are too large, X2s used two 1-3/32" carbies, not two 1-5/32".
#14 Posted : Tuesday, 17 March 2015 10:56:23 PM(UTC)
The 23-3014 & 23-3020 both ran from mid-HD (Nov 65) to the end of HG on 186 engines.
David 67HR Offline
#15 Posted : Wednesday, 18 March 2015 8:37:29 AM(UTC)
David 67HR
DR Terry,
I am running 2 1-3/32 Strombergs with a 223@050 Cam and a Good ported, bigger valve head from HSD
The 2 1-5/32 Strombergs will be with a 227@050 XU1 Street Grind cam a 262HP Flow tested Head
Edited by user Wednesday, 18 March 2015 8:39:14 AM(UTC)  | Reason: Not specified
castellan Offline
#16 Posted : Wednesday, 18 March 2015 10:22:58 PM(UTC)
castellan
Originally posted by David 67HR
DR Terry,
Why ?
What intake you running ?
I seen my mates worked LH 202 with twin small 1-3.32 strombergs hose of every a triple SU that was the fastest in their towns, the dudes could not believe it when they seen twin strombergs they started looking for nitrous.
He put the bigger 1-5/32 on and lost power. he had a 30/70 HYD cam that went just as well the 35/75 solid cam.
He had triple SU but said it only was right at top end that they gave more power and that was not as good in drag racing or for the road.
He has built up 3 308 V8's and says non of them are anything near the performance that old 202 he had.
He just had a hard time keeping the 202 blocks together as they would split the blocks on the passenger side all the way.
David 67HR Offline
#17 Posted : Wednesday, 18 March 2015 11:10:13 PM(UTC)
David 67HR
Running a Genuine Holden X2 Manifold
David 67HR Offline
#18 Posted : Wednesday, 18 March 2015 11:25:44 PM(UTC)
David 67HR
Do you mean that the 1 5/32 will send too much or not enough fuel in DR Terry or are they physically too big to fit the manifold? Please explain as I value your input
#19 Posted : Thursday, 19 March 2015 12:02:42 AM(UTC)
The carbies will fit, but the hole is smaller in the manifold than in the carby base. This will then put a 'step' where the airflow is most important.
Also a bigger carby doesn't deliver more fuel, it delivers more air. This is why the venturi size is critical. Too big a venturi leads to flat spots etc.
David 67HR Offline
#20 Posted : Friday, 20 March 2015 12:56:10 AM(UTC)
David 67HR
I understand now, thanks Dr Terry. So with a 262HP Head and a 227@050 XU1 Street Grind cam would Twin 1 3/32 Strombergs be suitable
