tufgmh Offline
#1 Posted : Monday, 27 April 2015 5:31:17 AM(UTC)
tufgmh
Hi all, I am currently restoring a VH SLE 5L to factory spec outside a few changes.
I would like to carry a HDT theme with the engine upgrades and am using B-cast heads, VK HDT air cleaner and snorkel, Crane 286 cam, 3.08:1 gears and a 2800 stall.
What exhaust headers did HDT use at the time, and which companies were supplying aftermarket? I have a set of Genie headers currently.
starks Offline
#2 Posted : Monday, 27 April 2015 8:00:23 AM(UTC)
starks
I dont know what headers HDT supplied exactly but from memory GM wouldn't allow extractors to be fitted so they left HDT with factory cast headers and extractors in the trunk you could get fitted yourself.
#3 Posted : Monday, 27 April 2015 11:29:45 AM(UTC)
Meeting emissions was the issue why GMH wouldn't allow them to be officially fitted. Media in the period quite often quoted the "headers in the boot" story, but most were fitted by either the dealers or HDT themselves (as evidenced on paperwork from some VHs).
HM was used on most of them - and they are now doing period resto supply of the original VH/VK style - for a price, which is fairly reasonable.
However, don't toss out a good set of Genies if they're not leaking - Genie was also fitted by HDT in the 80s. I can't say for sure on VH, as I haven't seen documented evidence from one, but on my VL's HDT build sheets it has HM crossed out, and Genie handwritten on there, along with the name of the person who fitted them (in the same handwriting). When discussing this with people who actually worked ON the cars back in the day (as opposed to internet fame seekers who claim they did, but know jack s*** & the fulla arm of his family), this happened often - either through low stock during peak times, or stop-credit on unpaid invoices.
I have since removed the Genies off my car, as they were original, and leaked like a sieve at every Y joint. I now run ceramic coated pacemakers, and no longer melt the passenger carpet.
tufgmh Offline
#4 Posted : Tuesday, 28 April 2015 5:09:47 AM(UTC)
tufgmh
Cheers Mick, the Genies are in great condition, so if they were around at about the time VH's were, that's good enough here ;) I prefer Pacemakers due to the removal of the 3bolt flange that is a pain to get to on the Genies, but if they're there, fit the theme wanted, and they work then they can stay.
Another likeminded query:
-With the Holden "New engine blue", was it originally painted on the long engine covering all bolts on the sump and rocker covers? And were the white letter markings on the rocker covers anything of great value and worth replicating? A 253 SLE here has VV on the inner middle of the passenger rocker cover.
Thanks, Aaron.
#5 Posted : Tuesday, 28 April 2015 8:15:59 AM(UTC)
Yes, the blue went everywhere - over those bolts you have mentioned (unless you had the HDT chrome covers).
Looking at numerous original blue 308 engines I've stripped down over the years, it appears they had a "mask" that sat over the manifold, and another for the water pump & timing cover areas to shield them from overspray. I've seen the same "escape spray" patterns on the lower front face of the manifold, and on the timing cover, on a number of original blue 308s I've torn down over the years to back that up.
The white letters never seemed to last - so whatever they were applied with was not meant to be durable once the engine got hot. Would I try to replicate them? Personally, no. But I'd be fitting chrome rocker covers which never got them. I'd suggest hat as an idea for your car - chrome rocker covers just like the VH HDT cars had, along with a chrome air cleaner lid for that big-mouth cleaner you've got to match up to the snorkel.
There's still some original cars getting around with the old cardboard tag wired onto the lower front of the block - that's worth replicating if you can find a clean one to read. All the ones I've had were soaked in oil & grease - they were beyond black!
#6 Posted : Tuesday, 28 April 2015 4:48:57 PM(UTC)
Reds were exactly the same Mick. The bellhousing and flex plate copped overspray as well.
