HR235 Offline
#1 Posted : Thursday, 30 April 2015 3:43:40 AM(UTC)
HR235
Hi All,
Is there any internal differences, engine wise, between the standard 186 and the 186S engines? I'm aware of the external differences - carby, air cleaner, headers etc, but am not aware of any internal differences.
Thanks in advance.
#2 Posted : Thursday, 30 April 2015 4:11:31 AM(UTC)
Crankshaft, camshaft and exhaist valves.
Warren
#3 Posted : Thursday, 30 April 2015 4:12:50 AM(UTC)
The main differences are the use of a forged crankshaft, more durable main & conrod bearing material & a different camshaft with more valve timing overlap.
The valves are the same size, however the exhaust valves were upgraded to withstand higher temperatures.
gm5735 Offline
#4 Posted : Thursday, 30 April 2015 5:23:28 AM(UTC)
gm5735
The 186S also has higher rate valve springs.
#5 Posted : Thursday, 30 April 2015 6:40:17 AM(UTC)
Depends upon which series you are referring to, example HT 186 used the 186S camshaft and exhaust valves. Trimatic fitted 186 and 186S engines used the HK 186 camshaft.
