jayHK69 Offline
#1 Posted : Thursday, 14 May 2015 8:26:13 PM(UTC)
jayHK69
is the brake line bracket for 10 bolt diff inter changeable (if that`s a word) between the HK & HQ models ?
jason
gm5735 Offline
#2 Posted : Thursday, 14 May 2015 9:25:47 PM(UTC)
gm5735
I thought that bracket was welded to the right hand diff tube on HK. On HT and HG it is bolted to the diff centre using two of the rear cover bolts and spacers. I believe HQ has the bracket as part of the diff centre casting, although this reverted to bolted for WB.
In short, no they are not interchangeable, and yes, it is a word.
#3 Posted : Friday, 15 May 2015 12:47:25 AM(UTC)
HK are different to HT-HG as well. HK's are just a flat plate cut into the shape it is, HT-HG are an elaborate bent and fabricated thing. HT-HG are harder to find but I have a few of the damn things and no HK ones! At least repro HK ones are cheap on Ebay.
jayHK69 Offline
#4 Posted : Friday, 15 May 2015 5:29:13 AM(UTC)
jayHK69
thanks for the replies & helpful info & the spelling
i`d forgotten that the diff in my HK actually came out of a HG, so it has the separate bracket.have found the correct bracket kit
jason
gm5735 Offline
#5 Posted : Friday, 15 May 2015 9:16:10 AM(UTC)
gm5735
Right you are Byron, the bracket is welded on HK banjos, not 10 bolt. My mistake.
