Jul71-Oct74 Offline
#1 Posted : Friday, 31 July 2015 3:30:06 AM(UTC)
Jul71-Oct74
Hi All
Just wanted to describe the symptoms of a problem I've got with my HQ 202 with standard strommy.The car runs perfectly in all stiuations except when I put my foot down for more power at speed on really steep hills the engine starts to falter. Get to the top of the hill and put your foot down and its all good again.
My first thought is float level which I'll check today, but was wondering if anyone could give me some pointers as to other things that could cause this.
Cheers in advance
Rick
#2 Posted : Friday, 31 July 2015 5:54:21 AM(UTC)
Put a 308 in it. That usually fixes that problem.
#3 Posted : Friday, 31 July 2015 11:17:47 AM(UTC)
Bit facetious.
Try a new fuel filter there may be 2 of them one at the tank and one in the engine bay.
also the accelerator pump in the carby could be faulty do you get a good squirt of fuel when you push the linkage down hard (withe engine turned off and the car stationary take the air cleaner .
off and look down the barrel of the carby).
also check the plug leads could be one breaking down under strain, check the resistance in them. have a look at night in the dark with the engine running you might see sparks jumping off the leads.
#4 Posted : Friday, 31 July 2015 4:15:15 PM(UTC)
My guess is timing.
gm5735 Offline
#5 Posted : Friday, 31 July 2015 10:43:01 PM(UTC)
gm5735
Does it actually miss, or just sag in power output?
You mentioned that the problem is only evident on hills. Do you get the same effect using a high gear at low speed and accelerating heavily?
I'm wondering if it's the load on the engine, or the attitude of the car that causes the problem.
#6 Posted : Saturday, 1 August 2015 3:10:00 AM(UTC)
Is it an auto or manual? Could be fuel restriction as John hints or even a failing fuel pump or similar. Is it a late HQ with canister?
Jul71-Oct74 Offline
#7 Posted : Saturday, 1 August 2015 3:48:43 PM(UTC)
Jul71-Oct74
Guys, Its a trimatic and it does not have a canister. gm5735- I'd say it actually misses as opposed to just sagging in power output. High gear/low speed acceleration is good.
In any driving situation except hard acceleration on steep hills its pretty much faultless.
Ive tried various timing settings and that does not seem to influence it. Ive changed the fuel filter and that also didn't influence it. Leads are in good condition, but will definitely put my spare set on and try this. Accelerator pump seems ok.
#8 Posted : Saturday, 1 August 2015 5:03:53 PM(UTC)
It may be the condenser in the dizzy failing under load too.
JBM Offline
#9 Posted : Saturday, 1 August 2015 10:02:53 PM(UTC)
JBM
Does the auto kick down OK? You may have a vacuum leak or misconnected hose.
Edited by user Saturday, 1 August 2015 10:05:14 PM(UTC)  | Reason: Not specified
gm5735 Offline
#10 Posted : Saturday, 1 August 2015 11:16:21 PM(UTC)
gm5735
Richard, I wondered if it was the attitude of the car, rather than the engine load causing the problem.
I'll resist the temptation to to flippantly advise that you have insufficent cubic inches, since that has already been done.
Some of the best possibilities have been covered by John, Byron and others, but I'll elaborate on a few.
The fuel pump uses vacuum to draw fuel from the tank, so a dodgy fuel pump check valve, and/or leaks in the pipes from the tank to the pump would cause the pump to struggle, particularly when it has to draw fuel to a greater height such as when the car is on a "really steep hill".
If you have access to the equipment a pressure test of the pump output with the engine at idle should show between 3 and 5 p.s.i.
If fitted, the screen on the fuel pickup (in the tank)could also be partially blocked, and you could also have water in the fuel tank which only gets drawn into the pickup when the front of the car is elevated. If you have the clear sight glass on the pump you may see some evidence of this.
Plug leads are a likely cause too. You can test them with an ohm meter. You should see between 4000 and 8000 ohms per foot. (Assuming they are carbon string type leads). Don't forget the one from coil to the distributor cap.
The condensor is a possibility too. In a Kettering ignition system it extends the duration of the spark after the points open, and if it is weak or low in value, or improperly connected, you will have a short duration spark and less ability to ignite rich fuel/air mixtures. Check that the earth screw securing it to the distributor is tight, and that the connection is clean, and do the same at the points end. Or just replace it.
For a similar reason it would be worth checking the point gap.
Is the car actually in the UK? If so, I assume that may make getting bits and pieces difficult.
Good luck.
#11 Posted : Sunday, 2 August 2015 2:41:08 AM(UTC)
Is it pinging under load as well??
Jul71-Oct74 Offline
#12 Posted : Monday, 3 August 2015 7:48:14 PM(UTC)
Jul71-Oct74
gm5735- Thanks for all those tips. I'm going through them one by one
Yes the car is in the UK, but I have a good stock of most things including spare fuel pump, dizzy, carb kit and basic stuff like points and condenser I can get over here. I changed the plug leads today, but no influence on the problem .Plugs, points and condenser are virtually new and all contacts are good.
I did manage to get it to falter on a flat surface today so it looks like it is more to do with outright load level than the result of being on a steep incline. Kickdown also seems to work fine.
As much as I like the 308 idea, I don't have one of those over here, so I'm going to have to chase down the problem with the 202!
Just to put something else into the mix, I use Castrol Valvemaster lead replacement in every second tank of fuel I buy. A friend over here with a MK3 Cortina won't use it as he reckons over time it leaves sticky residues in the carb that ultimately give you the kind of problem I've got now. I'm not sure if this is true or just a myth, but the plan is to give the carby a good clean and see if that helps. I'll let you guys know if that solves it, but thanks to everyone for giving me a list of possibilities.
#13 Posted : Tuesday, 4 August 2015 2:03:31 AM(UTC)
Maybe it just hates being in the UK and wants to come home?
I bet it turns a few heads over there! Shame it doesn't have a V8 in it. That would really stand out.
Good luck with it. Sounds like a fuel problem.
castellan Offline
#14 Posted : Friday, 21 August 2015 6:48:30 AM(UTC)
castellan
Is the dizzy mechanical advance working ? stuck or broken spring ? and just advancing on the vacuum advance side.
Put a timing light on it with the vacuum dis connected and see what she does.
