#1 Posted : Monday, 10 November 2003 10:07:28 PM(UTC)
Hi all,
My ZH will get a hot 390 fitted very soon.
Bit of backlash in the diff though, could be time for a new one
I suspect it runs a 2.89
any recomendations for other ratios?
i think 4.11 is a bit extreme for street use
3.55 perhaps?
#2 Posted : Monday, 10 November 2003 11:08:46 PM(UTC)
4.11's aint to extreme but I'd be working out what rpm the cam works in. If it doesn't rev over 6000rpm go for 3.5's.
Brenden
#3 Posted : Tuesday, 11 November 2003 12:00:27 AM(UTC)
Thanks Brendan
your right, I need to get the cam specs...pretty wild cam I'd say considering i'm getting a 2500 stall converter with it
3.5's???
still be good for highway driving or will the revs be too high?
#4 Posted : Tuesday, 11 November 2003 5:40:46 AM(UTC)
i had a 3.5 in behind my 351 and i found it was reving too much at hyway speed.although i have always liked my engines to rev a little lower as it seems to give them a much longer life and seem to be user friendly.i dont think it makes that much differenc
#5 Posted : Tuesday, 11 November 2003 6:14:51 AM(UTC)
3.5's will be fine, as 2500rpm histall and 3.5's is a good match.
If you had a 3000rpm histall I'd suggest 3.7's.
3.5 should be about 2800-2900rpm @ 100kph.
I sit about 3500-3600 with 4.11's.
Brenden
Guest (5)
