#1 Posted : Thursday, 15 January 2004 10:14:31 PM(UTC)
What does it mean by when someone says they have a manualised C4? Is this just shifting through the gears?
#2 Posted : Thursday, 15 January 2004 11:03:59 PM(UTC)
Yes, you have to manual shift up/down gears. You can throw 1st gear @ 100kph. It's user friendly you might say.
It also gives you a shift that jolts your neck. Harsher than a stage II shift kit. Feels like it'll destroy uni's and diff's pretty well
#3 Posted : Friday, 16 January 2004 7:38:37 PM(UTC)
So you can't use it as a normal auto? Just let it do the work or can it still be used like that?
#4 Posted : Friday, 16 January 2004 8:46:57 PM(UTC)
That's correct.... it's like driving without a clutch but you still need to shift. had one in my chevy a few years ago and was great. The trans was sold to a friend and in it's 11 years of abuse has never needed a rebuild...keep in mind that we usually o
78XC Offline
#5 Posted : Thursday, 15 May 2008 5:24:47 AM(UTC)
78XC
Ive got one in my ford as I have just gotton it, it feels pretty good shifts hard and solid very direct cherp's the wheels every shift to bad if your in front of cops....
snappa Offline
#6 Posted : Thursday, 15 May 2008 6:06:02 AM(UTC)
snappa
Yea I spoke with Transgo shift kit dealer about stage3 he suggested stage2 , same shift (hard and fast) . do not have to shift gears. My transmission guy said good choice going with Transgo as they are hard to beat. A lot better than B&M
351 ZH
351 ZH
#7 Posted : Thursday, 28 August 2008 1:07:34 AM(UTC)
stage 2 does it do what its told? for example go down a gear when u want it to
#8 Posted : Thursday, 28 August 2008 2:49:17 AM(UTC)
yes a stage 2 can still be driven like a manual but you can also just put it in drive and it will change up and down by itself.
Guest (5)
