#1 Posted : Wednesday, 12 May 2004 2:40:03 AM(UTC)
i have been told that the master cyl is different on cars with a disc diff compared to a car with a drum diff.is this true or a load of shit.i carn't see them changing the master cyl for a minor change,but i could be wrong.thanks
#2 Posted : Wednesday, 12 May 2004 11:11:12 PM(UTC)
Yes the master cylinder is different in that it doesn't have a residual line pressure valve in it when used with disc brakes.
You can get the residual line pressure valve removed to convert the master cylinder for use with discs.
#3 Posted : Thursday, 13 May 2004 6:42:35 AM(UTC)
can you put a disc diff into a drum car without any probs or is it a must to change the master cyl?thanks for the info too :)
#4 Posted : Thursday, 13 May 2004 7:38:34 PM(UTC)
Yes, you can. Just remove the valve otherwise the discs will drag.
Remember the all important handbrake cable too.
I've done the drum --> disc conversion on my XB. My master cyl didn't even have the valve in it. Car may have been a disc b
#5 Posted : Sunday, 23 May 2004 3:51:18 AM(UTC)
where is this line valve and how do you remove it?
#6 Posted : Saturday, 29 May 2004 8:46:10 PM(UTC)
It's in the port where the brake line screws into the master cylinder.
Guest (6)
This page was generated in 0.097 seconds.
