#1 Posted : Monday, 7 June 2004 6:24:22 AM(UTC)
hi there guys i have an xb and since i lowered it in the rear (2 inches) have a slight vibration at about 100.....the tailshaft got balanced about 12 months ago because it vibrated a little, but i know it wouldn't be that, i have heard that you can buy a spacer to put under the gearbox mount to put the tailshaft in the correct alignemnt again, is this true? if so where can you get them? thanks in advance.......Mark
#2 Posted : Monday, 7 June 2004 10:17:37 AM(UTC)
What may help you more is aspacer or "wedge" between the leaf springs and the axle tubes. These wedges are readily available for use with traction bars and are very cheap. A spacer for the gear box will not change the angle of the pinion which i
#3 Posted : Tuesday, 8 June 2004 3:30:30 AM(UTC)
I had the same issue when I lowered my XB. I put the lowering blocks above the leaf but ontop of the saddle. Which made a silly pinion angle. After multiple attempts trying to solve vibrations Going to tailshaft places (got the tailshaft done 3 times) and
#4 Posted : Tuesday, 8 June 2004 10:01:25 PM(UTC)
Mark your hotmail email address is bouncing.
Here's a link to the pic.
http://home.iprimus.com.au/bwill/100_2078.jpg
#5 Posted : Friday, 11 June 2004 8:01:49 AM(UTC)
thanks for your reply's guys, much appreciated!!
#6 Posted : Sunday, 27 February 2005 7:02:04 AM(UTC)
hi guys, i have the same vibration problems with a 302W into 1970 capri. diff is a 9inch& C4 box.im onto my 2nd tailshaft but i think he gave me the wrong size uni's cos its still vibrating.im hoping the right size uni fixes the problem, goodluck fellow v
Guest (5)
This page was generated in 0.098 seconds.
