#1 Posted : Thursday, 15 July 2004 8:44:12 AM(UTC)
Guys, How do you get the clutch fan assembly off the water pump shaft on an EB falcon water pump. Tried holding impeller in vice and turning nut behind clutch assembly, but shaft spins inside impeller. Any ideas? Thanks in advance.
#2 Posted : Thursday, 15 July 2004 8:19:20 PM(UTC)
It's a left hand thread. Are you turning it the right way?
#3 Posted : Thursday, 15 July 2004 11:03:51 PM(UTC)
#4 Posted : Friday, 16 July 2004 3:38:35 AM(UTC)
Look behind the fan hub, you'll see a nut. Turn this while holding the shaft.
#5 Posted : Friday, 16 July 2004 8:08:22 AM(UTC)
You can get a specific spanner for this job as there isn't much room to get a regular spanner down behind the fan. It's quite flat steel with a kink in the middle. I'm normally loathe to buy specialised tools but this made the job heaps easier.
#6 Posted : Monday, 19 July 2004 4:50:19 AM(UTC)
Yeah thanks fellas. I already had the pump out. Knew it was left hand thread, but just couldnt hold the shaft to undo it. The shaft was spinning inside the threaded assembly where the nut screws on to. In the end i was about to cut the sucker off with
#7 Posted : Friday, 23 July 2004 8:36:22 AM(UTC)
the spanner that is required can be made from 6mm x 40mm x 300mm flat bar any Genuine ford manual will give measurments and I think from memory a 1.250 af spanner I had to bend and reduse the thicknes on the one I had also if poss take of car before remo
#8 Posted : Tuesday, 12 October 2004 11:40:04 PM(UTC)
use two spanners to hold the shaft
