#1 Posted : Monday, 18 October 2004 5:07:32 AM(UTC)
I have an XF wagon on LPG with a
3 spd auro b/w gear box. Am looking at options to improve economy (many highway km's travelled)and hear that the b/w Model 40 g/box fitted to the ZL fairlanes had an internal o/drive - ie you could not select o.d. from gear selector. Does anyone know if this is true ? Other option is to change to a lower diff - any thoughts?
thanks
Andrew
#2 Posted : Monday, 18 October 2004 6:38:00 PM(UTC)
from what i know there is no difference between a xf and zl box.i have never heard of an overdrive in these boxes.a 2.77 diff would make a difference if your car doesn't already have 1.a manual would also be cheaper on fuel but you'd have to find 1 then c
#3 Posted : Tuesday, 19 October 2004 12:20:47 AM(UTC)
i was once asked how do i want t spend to save? fitting a new gearbox could cost a bit to get it all work properly..
I would suggest that jsut make sure things like timing is right, plugs are good, oild is good etc etc, as these certainly wont help econ
#4 Posted : Tuesday, 19 October 2004 12:44:49 AM(UTC)
No the b/w model 40 found in XF's and ZL's doesn't have an over drive. 3rd gear is a 1:1. later model g/boxs from late EA and up to AU have a 4th gear over drive but fitting one of these boxs may be difficult and expensive. a better option may be to get a
#5 Posted : Tuesday, 19 October 2004 3:56:40 AM(UTC)
They weren't very popular and the aren't very strong. A few people have them behind their V8's.
#6 Posted : Tuesday, 19 October 2004 9:57:27 PM(UTC)
E series gearboxs wil be harder to fit to X series cars because the starter motor is on the other side (passengers side) of the motor on E series...
Just a quick thought...
#7 Posted : Thursday, 21 October 2004 12:19:31 AM(UTC)
Thanks Tuff 250,
The 2.77 diff seems the way to go, to a layment what's the difference between an LSD and a normal diff and would one fit onto a wagon?
Would i be able to use my same axels (with discs) and just replace the diff itself. Do you know
#8 Posted : Thursday, 21 October 2004 6:54:49 AM(UTC)
sorry mate i didn't realise you had a wagon.xf sedan and wagon diffs are different because a wagon has leaf springs and a sedan has coils(which means different mounting points).a lsd spins both wheels where a normal diff only spins 1 on dry bitumen.it don
#9 Posted : Friday, 22 October 2004 4:30:03 PM(UTC)
QUOTE: "an LSD spins both wheels". A more adequate description would be: An LSD delivers power to the wheel with the most traction. If for instance a vehicle has one rear wheel on the road and the other on the gravel shoulder. initial accelerati
#10 Posted : Monday, 10 January 2005 2:33:03 AM(UTC)
