YetAnotherForum.NET Help
#1 Posted : Saturday, 1 May 2004 9:45:28 PM(UTC)
Has anyone got any tips on getting a HZ door open that seems to be stuck in the lock position without destroying the door trim? The lock mechanism is stuck in the lock position and the door won't open. Thanks heaps for any info...
#2 Posted : Sunday, 2 May 2004 2:30:21 AM(UTC)
You probably tried to lock the door with the handle half up. Try pushing the locking button all the way down, push the outer handle properly shut, and the try unlocking it again with the key or by pulling the locking button, you may have to fiddle a bit w
#3 Posted : Sunday, 2 May 2004 3:57:42 AM(UTC)
Wind the window down, remove the outer chrome trim, and push the window over as much as possible towards the outer door skin. (you might have to slide out the window runner felt).
You should then have enough room to insert a strong/rigid piece of heavy g
#4 Posted : Sunday, 2 May 2004 7:05:28 PM(UTC)
Make sure the door is firmly shut as well. I had this happen, lent hard on the door and then it opened.
sandman77 Offline
#5 Posted : Tuesday, 4 April 2006 7:39:41 AM(UTC)
sandman77
Try And get the trim off , or get someone to open the handle from the outside while you are inside with both your feet on the inside ,now with both feet kick the door open .
hairy-dude Offline
#6 Posted : Tuesday, 4 April 2006 10:28:53 AM(UTC)
hairy-dude
I used to have this problem when I changed the locks in my old HZ. To get the door open I had to thump the door, just below the lock from memory. The pushrod from the external handle would jam up, and if I thumped the door in the right place, it would dis
sandman77 Offline
#7 Posted : Thursday, 6 April 2006 6:56:32 AM(UTC)
sandman77
If That doesnt work you might have to sacrifice the door trim a little ,Once your inside grab a torch & have a look in , Then Spray some CRC & start moving all the objects while still trying to push the door open I'm pretty confident you should be able
Tour Director Offline
#8 Posted : Thursday, 6 April 2006 7:07:00 AM(UTC)
Tour Director
The RACV,NRMA etc can usually open a door with one of their special levers.Then as suggested once you have the door open,take off the trim ,and using a torch to view, spray some CRC or similar around the lock.Work the lock/knob/key so you can see what wor
sandman77 Offline
#9 Posted : Thursday, 6 April 2006 7:16:01 AM(UTC)
sandman77
You could always get a Air chizel & sacfifice the door on the outside ,If the door has heaps of rust on the inside & outside then this could be an option . If you dont have an Air Chizel then just grap a good size hammer & a normal sharp Chizel . Don't fo
#10 Posted : Thursday, 6 April 2006 9:18:07 AM(UTC)
Guys, The original post above is 11 months old now...I reckon he has either got the door open or sold the car by now... :-)
Cheers...Dave
Edited by user Thursday, 6 April 2006 11:04:34 AM(UTC)  | Reason: Not specified
sandman77 Offline
#11 Posted : Friday, 7 April 2006 9:00:02 AM(UTC)
sandman77
Yes ,That is correct ,you are absolutely right , just thought we would add our opinion, I dug that post up from the dead ,hahah.
but enjoyed talking about it ,great topic to talk about don't you think ? hahahah
cheers .....Rus
Mr Void Offline
#12 Posted : Saturday, 8 April 2006 1:33:42 AM(UTC)
Mr Void
I'm glad you did bring it back up because I've been wondering for almost a year now whether or not he got the door open!!
AND I STILL DON'T KNOW!!!!!!
..no wonder I'm losing my hair....!
___________________
Why are you reading this, you should
___________________
VL05 Offline
#13 Posted : Saturday, 8 April 2006 3:33:34 AM(UTC)
VL05
Maybe the other door got stuck and now he lives in his car?
WANTED: GTS rims, seats and mirrors to suit HJ.
#14 Posted : Saturday, 8 April 2006 5:42:38 AM(UTC)
i've got the same problem, maybe i bought his car!!!!
sandman77 Offline
#15 Posted : Saturday, 8 April 2006 6:17:58 AM(UTC)
sandman77
Hahahaha,
Well if anyone ever has that same problem ,They sure as hell know that there are plenty of options available to them to solve it ,Does anyone know any more realistic options if one was to have the same problem . (door not opening)
What i
#16 Posted : Saturday, 8 April 2006 9:32:22 AM(UTC)
Opening a bonnet where the cable has broken is easy peasy....Either remove grille or look through it (depending on grille) and you will see a tab of steel hanging down under the catch.
If you remove the grille, use pliers/multigrios/vicegrips to move
sandman77 Offline
#17 Posted : Sunday, 9 April 2006 8:31:58 PM(UTC)
sandman77
Cool man
yes correctomondo :)
Rusty
Mr Void Offline
#18 Posted : Sunday, 9 April 2006 10:42:53 PM(UTC)
Mr Void
So what? Now that you have the bonnet open you are going to cut a hole in the firewall and get into the cab through it??
If you were living in the cab why would you want to open the bonnet anyway? You guys just don't make any sense some times??!!
___________________
Intoit Offline
#19 Posted : Monday, 10 April 2006 4:35:01 AM(UTC)
Intoit
What about poor Toby , has anybody bothered to let him out of the car yet ?
--------------------Go Hard Or Go Home
