#1 Posted : Thursday, 20 May 2004 8:54:52 PM(UTC)
I am looking at ditching the 3 Speed crash box in favour of something better to drive behind the 179 with HR disc front. I am buying a CRS chassis kit and getting the tunnel enlarged and was thinking about going to an auto (t700) after reading the street machine story and some other reviews. I recently drove an EK with a supra box and realised that I would miss the engine braking effect of downshifting if I went Auto and am now considering a manual box. Problem is I have a new bench seat that I want to keep and have heard that the only box to clear this would be an Aussie 4 sp with a bench shift kit. Is this correct or are there other options. Also is the Aussie any good or will it be as whiney and clunky as the 3 speed?
#2 Posted : Thursday, 20 May 2004 11:16:04 PM(UTC)
Use the Aussie, but rebuild it first. Use an M22 though, with a 3.08 or 2.78 diff, which effectively gives you an overdrive 3-speed, but 1st gear is still usable. That way you can use the bent floor shifter. The M22 will easily handle your 179. Clutches,
#3 Posted : Friday, 21 May 2004 1:34:04 AM(UTC)
How do you pick an M22?
As I am wanting to put an M22/3.08 combo into my 1 Tonner...
Victa.
#4 Posted : Friday, 21 May 2004 6:51:28 AM(UTC)
From the ratios, or from the part numbers on the cluster gear or input shaft or third gear. Put it in 1st and count - 3.74:1 for M22, 3.05:1 for M20 and 2.54 for M21. The M22 is only a 6cyl box though you can convert one to a V8 with a V8 3-speed input sh
#5 Posted : Friday, 21 May 2004 5:35:18 PM(UTC)
I thought the m22 had a 2.85:1 first. Is there anywhere on the net where the ratios are available?
#6 Posted : Friday, 21 May 2004 6:11:46 PM(UTC)
The M22 has the same (or close)first gear ratio as an M15 (3-speed). I will be putting some of this info on my website soon, but it's not there yet.
#7 Posted : Friday, 21 May 2004 8:10:44 PM(UTC)
Will an M22 stand up to a stock 253?
Victa.
#8 Posted : Saturday, 22 May 2004 2:52:20 AM(UTC)
Absolutely no difference in strength between an M22, M21 or M20 EXCEPT that dumping the clutch on an M21 with a V8 into a high geared LSD arse end (eg 3.08:1) will probably more likely break an M21 than an M22 simply because more loading is placed onto th
#9 Posted : Saturday, 22 May 2004 6:13:36 AM(UTC)
Hi Guys.
I'll have to disagree here, the 1st gear ratio of the M22 box is a super-low 3.74.
Here's a list of 1st gear ratios (GM-H 'Aussie boxes only)
M15 3-sp.....3.07
M20 4-sp.....3.05
M21 4-sp.....2.54
M22 4-sp.....3.74
The o
#10 Posted : Saturday, 22 May 2004 8:20:49 PM(UTC)
You're right about the 1st gear on the 3-speed. My memory failed me there. But I wasn't aware of two different ratios on the 3-speed 2nd gear (which co-incidentally is the same as 3rd on an M22) which should be 1.68:1 on all 3-speeds. The only different o
#11 Posted : Sunday, 23 May 2004 6:35:27 PM(UTC)
Hi Byron.
It looks like we're both having memory failure. You are correct, it is the 1st gear that differs in the HT V8 M15, not 2nd as I suggested.
When it gets to M21 boxes, there are quite a few variations. There's the regular (V8) M21 box
#12 Posted : Monday, 24 May 2004 7:03:50 PM(UTC)
The VB rally cars were a wierd thing. A lot of the running gear was left over XU-1 stuff. The input shaft was still available new from GMH in the late 80's. A friend of mine had one of the cars until a few years back. I think it was the 4th Holden Dealer
#13 Posted : Friday, 26 November 2004 11:02:38 PM(UTC)
hey mate i jsut read your post cause i am searching for info on gearboxes. looking at putting a v6 in a eh with t5 or a t700... go any ideas or info on how u went? email me :)
Guest (10)
