2 Pages<12
shifty350 Offline
#21 Posted : Tuesday, 17 June 2008 7:15:18 AM(UTC)
shifty350
All, HK Holdens all use the same front suspension crossmember. The lightening holes in the outrigger are simply that. In 1969, the circular hole became a handy place to run the power steering hoses through on the GTS 327 model (if so equipped) as 307 cont
80737k Offline
#22 Posted : Tuesday, 17 June 2008 8:29:21 AM(UTC)
80737k
Thanks Shifty, sounds more than plausable. The solid i had has gone as i sold the car, pitty i cant get its date code :-{{
the solid i had was in a HT prem but no guarantee it was original in that car (auto 6 cyl).
Hazard, can you grab the date code fro
Fossil fuels are YUMMY !
80737k Offline
#23 Posted : Tuesday, 17 June 2008 8:29:21 AM(UTC)
80737k
Thanks Shifty, sounds more than plausable. The solid i had has gone as i sold the car, pitty i can't get it's date code :-{{
hazzard county Offline
#24 Posted : Wednesday, 18 June 2008 12:05:47 PM(UTC)
hazzard county
looked all over cant find a date all i found was a stamp (ht) on the lower control arms but has had a few coats of paint over the years may be buried under that
#25 Posted : Wednesday, 18 June 2008 11:00:02 PM(UTC)
Hi Guys.
I have never taken note of when this change took place, but its not different between 6 & V8 engined cars. It probable changed somewhere in late HT or early HG.
I have seen many of the early ones (with the holes) cracked, so maybe Holden ju
#26 Posted : Wednesday, 18 June 2008 11:00:02 PM(UTC)
Hi Guys.
I have never taken note of when this change took place, but it's not different between 6 & V8 engined cars. It probable changed somewhere in late HT or early HG.
2 Pages<12
