#1 Posted : Wednesday, 4 August 2004 8:43:16 PM(UTC)
Hi all, what are the advantages/disadvantages for the 2 types of O2 sensor? ie which ones better, the 4 wire or the single wire.
Anyone know why Holden changed over?
Cheers Dre
#2 Posted : Thursday, 5 August 2004 12:09:04 AM(UTC)
Hi Dre,
i believe the single wire ones are heated by exhaust gas, and the multiple wires are self heating.. heating up quicker will give u more accurate readings sooner after start up Im assuming.
Ed
#3 Posted : Thursday, 5 August 2004 1:51:11 AM(UTC)
Ahhhh, excellent, thought there must be a reason why they changed.
Ok, next question, can a computer for a 1 wire control a 4 wire O2 sensor? is it just a change in wiring or more than that?
Thanks for the info!
Cheers Dre
#4 Posted : Thursday, 5 August 2004 5:04:37 AM(UTC)
Hi Dre.
The 4 common types of 02 sensor are 1,2,4 & 4 wire.
They fall into 2 main types heated & un-heated. The 1 & 2 wire are un-heated & the 3 & 4 wire are heated. The 2 wire is the same as a 1 wire but with a seperate si
#5 Posted : Thursday, 5 August 2004 5:07:10 AM(UTC)
Hi Dre.
#6 Posted : Monday, 9 August 2004 11:00:23 PM(UTC)
Thanks for the info. I cant actually leave it as it is as I'm talking about the 308 in my kingswood (which I am in the process of putting an EFI manifold in place of the quad etc).
I have the bung in my extractors for an O2 sensor, so I'll just u
