#1 Posted : Monday, 9 August 2004 6:00:41 AM(UTC)
One of my headlights on my vk is realy dim i was thinking of just changing the bulb but i cant get it out. Ive removed the plastic/rubber thing at the back but seem to get it out. cant see any screws etc holding it in.
#2 Posted : Monday, 9 August 2004 8:12:51 AM(UTC)
I think there is a wire clip in the back of the globe that you remove.
#3 Posted : Tuesday, 10 August 2004 3:29:32 AM(UTC)
The headlight globe has a wire spring that holds it in.You depress one side of it and undo it like a safety pin.The dim effect may come from a dulled reflector.Sometimes water gets in and tarnishes the chrome plating. Some Taiwanese replacements also had
