#1 Posted : Friday, 20 August 2004 7:13:57 AM(UTC)
Are there any RTS experts out there? I have a HQ Monaro and I want to change steering and suspension to Radial Tuned Suspension, as found in HJ HX HZ etc. Aparently its a dramatic improvement ... so the books say. What is required? I have a steering arm from something later and its an inch longer, maybe more. Front and rear sway bars are a part of the RTS improvements but what else do I need? Is it possable? Thanks for any info. BM!
#2 Posted : Friday, 20 August 2004 8:27:51 AM(UTC)
RTS was only on HZ and WB. Basically you need to change your front rails for sedan/wagon/statesman, or whole chassis if ute/van/tonner.
#3 Posted : Friday, 20 August 2004 9:12:55 AM(UTC)
Thanks Byron, that will go in the too hard basket then.
#4 Posted : Friday, 20 August 2004 9:19:50 AM(UTC)
#5 Posted : Friday, 20 August 2004 7:58:11 PM(UTC)
In saying that, I improved my standard HJ years ago by fitting the HZ front and rear springs, HZ front and rear swaybars and using the HZ settings in the wheel alignments (or close to them). This made the car handle much better, not quite as good as a HZ
#6 Posted : Friday, 20 August 2004 10:23:17 PM(UTC)
It's not really difficult on a sedan/coupe. In fact it's a lot easier to paint, fit new suspension and bushes etc to a set of front rails off the car. Of course it's a bit more difficult to change the front springs without the car's weight. The biggest di
#7 Posted : Saturday, 21 August 2004 1:44:15 AM(UTC)
I changed the whole front chassis etc on a HJ I had bought that had been pranged, just unbolted everytrhing, wheeled old chassis out, new chassis in, did backyard wheel alignment (remember you have not changed the wheel alignment in the new chassis? on t
#8 Posted : Saturday, 21 August 2004 9:10:39 AM(UTC)
ThanX Byron. I might do that 1day when I have some time and $$$. I've fitted sway bars all round and my springs and shocks are illegaly low just the way I like it :-) It drives Ok now anyway. Thanks again
#9 Posted : Saturday, 21 August 2004 3:36:11 PM(UTC)
Changing to RTS by swapping subframes is a simple straight forward swap. Everything fits fine :-)
Some later HX's also had RTS so I've discovered.
The shorter steering arms you have are from a power steering setup.
#10 Posted : Sunday, 22 August 2004 12:37:25 AM(UTC)
Hi guys.
As Taz2 points out some late HXs had RTS.
Well almost.
The last 6 months of HX had the new control arm & new mounting points with the new alignment figures, but did not get the better springs & shocks & sway bars. Th
#11 Posted : Sunday, 22 August 2004 10:22:01 PM(UTC)
I did the same with my HQ.Threw away the std alignment specs and went for as much positive castor and neg camber as possible,without using too many shims,
