#1 Posted : Saturday, 25 September 2004 8:12:06 AM(UTC)
Hi, Just like to know if there is a long and short axle in the 10 bolt? I have two sets of axles from disc brake set up and they are all the same length but I also have a set from drum brake commercial and one is shorter then the other by 13mm. The parts book only lists one part number for both axles for each vehicle eg tonner axle p/n, wagon,sedan,ute axle p/n and Statesman (disc brake) axle p/n (longer studs). It seems to me there is no longer axle but I cannot understand why this ute diff I have has a shorter axle. Cheers Lee
#2 Posted : Sunday, 26 September 2004 4:46:17 AM(UTC)
There are only 5 different axles for the 10 bolt:
HQ-WB 1-tonner
HQ-WB drum brake (non tonner)
HZ-WB disc brake
A9X
Commodore
Both sides in each case are the same length.
#3 Posted : Sunday, 26 September 2004 7:58:22 AM(UTC)
Thanks for the reply Byron. I buggered up my information. It is actually one of the pair of disc brake axles I have which has a longer one in the set. I did not remove these as I received the diff in a disassembled state. With comparing everything I have
#4 Posted : Sunday, 26 September 2004 7:58:59 AM(UTC)
#5 Posted : Sunday, 26 September 2004 6:25:08 PM(UTC)
commodore are two different lengths.
#6 Posted : Monday, 27 September 2004 6:51:24 AM(UTC)
The shorter axle in the disc diff is to account for the thickness of the disc, so that the track width is not affected. The disc brake axle also has a smaller flange and a longer centre hub, plus longer studs. I also forgot to mention in my original post
#7 Posted : Monday, 27 September 2004 8:29:42 AM(UTC)
Would anyone have a spare disc brake axle for a WB laying around?
#8 Posted : Monday, 27 September 2004 9:44:39 PM(UTC)
Re disc brake vs drum brake axles. The *axles* themselves are no different. The difference lies in the spacer that sits between the wheel bearing and the plate that bolts to the diff flange.
You can convert a drum brake axle to a disc brake axle b
#9 Posted : Tuesday, 28 September 2004 4:08:14 AM(UTC)
Hi Guys.
I'm sorry Dre, but Byron is correct. You can't fit HZ/WB rear disc rotors over the flange of drum-brake axles & the distance from the bearing ridge to the flange face is less on the disc brake axles.
The spacer in the bearing kit
#10 Posted : Tuesday, 28 September 2004 7:41:14 AM(UTC)
Where are you?
#11 Posted : Tuesday, 28 September 2004 7:10:07 PM(UTC)
Yeah I forgot about having to machine 1.5mm from the edge of the axle flange. This isn't enough to cause a problem though...
That spacer is required when using the disc brake setup as they are thicker and if not used you would have play in and out
#12 Posted : Tuesday, 28 September 2004 7:44:11 PM(UTC)
It is possible, but you need to machine the bearing surface further up the axle closer to the flange, cut about 1/2" off the end of the axle, machine down the flange so that the rotor will fit over it and fit longer wheel studs. You then still have t
#13 Posted : Tuesday, 28 September 2004 9:30:18 PM(UTC)
Or a a complete Commodore diff which is the way I'm heading...
Cheers Dre
#14 Posted : Tuesday, 28 September 2004 10:12:12 PM(UTC)
I agree. A complete VN diff is probably a better option. You can also fit Commodore rear disc brakes to a HQ-WB 10-bolt, but not sure of the specifics. Another simple mod is to get Holden ends and mounts welded onto an XA-XC 9" housing. If you get th
#15 Posted : Tuesday, 28 September 2004 11:02:51 PM(UTC)
Yeah you can fit the commodore disc brake setup to a 10 bolt, requires a bit of machining to the axle flange and the center of the disc but it all fits. Oh and VH commo wheel bearings.
I plan to run a late model non-irs diff in my HZ and get the ax
#16 Posted : Wednesday, 29 September 2004 6:37:17 AM(UTC)
I'd seriously condiser redrilling the front discs to 120mm PCD and get some 17" rims eg VY SS. Tyres for these are cheap nowadays.
#17 Posted : Wednesday, 29 September 2004 8:59:19 AM(UTC)
Right, I think I have this axle thing sorted. After looking at my two axles a bit more carefully and comparing them with standard ones(drum brake) and reading all the comments, it appears I have one standard disc brake axle and one drum brake axle modifie
#18 Posted : Thursday, 30 September 2004 4:00:07 AM(UTC)
Hi TWODOGS.
I think that should work OK, just make sure you use some tough bolts on the caliper mounts.
If you mount it 10mm further out then the shear stress under heavy braking would be much more than standard.
Have you thought of having th
#19 Posted : Thursday, 30 September 2004 6:49:38 AM(UTC)
Hi Dr Terry the calliper will not be spaced out, it is the calliper mount from the axle housing flange that will get spaced out so the calliper bolts will remain standard and I want this so the calliper clears the leaf spring. The problem with the seal is
#20 Posted : Thursday, 30 September 2004 7:05:54 AM(UTC)
lee
hows that vn going
This page was generated in 0.103 seconds.
